My VX has a PCV from the factory
Got your attention right VX owners?
I'm an active user over at gassavers. I'm not yet allowed to post links as I have less than 5 posts. Go to gassavers and search vx pcv. The first article that comes up is "93' Civic VX horrible Fuel Economy." On page 3, about half way down, (starting with post #81) there are photos and a description of what I found. (maybe another user can post this link for me) To summarize what you will find over at gassavers, the PCV valve is actually a straight type pcv valve located at the breather box below the IM. It plugs in at the grommet to the hose that later feeds the hollow elbow that most people (including me) have assumed was the PCV valve. VX owners, please find the breather box under the IM and pull the end of the rubber hose going into it. At the end of the hose is a clamp and a plastic straight piece. When cleaned you will find PCV inards (spring, one way valve). Let me know if other VX's have this same set up! B |
Nope, neither my current nor past civic VX has a valve down there and both cars are very much stock, it's really hard to get to that lower hose unless you have help from someone with small hands, but on my first VX I took both hoses out and replaced them, along with the lower straight joint and the grommet all with parts from the dealership because that grommet over time dries out and causes the idle to bounce up and down.
Auto part stores will sell you generic parts that do have a check valve in them but the dealership does not and there is no need to replace those hallow joints because there is nothing inside of them to wear out or brake. |
Did you buy yours from the factory?
Have you done all the work on it yourself since the beginning? The part that I removed that has innards has the P07 part number in the middle of the number. That is what tells me it is stock. Now mine is 93', and I have not owned it since new. It is possible somebody put this in, I suppose, but I'm convinced that because it has the original part number that it is original. When I first pulled it out, it had failed open. It was so crudded up that I didn't realize it had a check valve in it. It flowed some air through it, but not a whole lot. I cleaned it with carb cleaner and shook it for some time. Once all the crap was dislodged, it worked again. (just as all other PCV valves have on all cars of mine before this one) My theory is this: VX's seem to have a pcv in either the lower straight valve location or in the upper elbow version. In fact, even aftermarket stores sell both for your car. On the majestichonda parts diagram, (still can't post links) they list the "pcv" as the elbow part but they don't carry a listing for the other "pcv" straight valve. So, if there were two style valves available in different models, and the dealer gave you the straight empty valve (thinking you had the PCV elbow valve), you'd have two open "valves." I really wish I could post links/photos so I could show you this discussion/photos of the part. I'm aware that aftermarket auto parts stores will sell you pcv valves with innards. I'm also aware that the dealer will sell you a "gutless" elbow or straight piece. My problem is, this part has the P07 part number in it. As far as I'm aware, that part number is only found on VX's. Did you by any chance keep the old hose/straight piece when you took it apart? B |
Oh, and yes, that is a very difficult place to get to. I get to it from the drivers side with my extra long needle nose pliers so I can remove the clamp.
B |
I forgot a couple of things:
Two other users on the other board found the identical component with innards. My second VX motor I have as a spare and it also has the same par. I pulled the part off the car so you can have the part number: 17130-PO7-A01 PACIFIC JAPAN Let me know what you come up with. B |
Okay, now I can make links.
93 Honda Civic VX horrible fuel economy - Page 4 - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum Post #83 is the first post that references it. I attached photos as well as another user did. B |
On my neighbor's truck, we were going to replace the PCV valve but couldn't because he has a vacuum leak and when we put in the new valve, the truck wouldn't idle. There was no question this was the PCV valve but we couldn't use the new one until he dealt with the vacuum leak since too much vacuum was being used up for the ventilation of the crankshaft. A bit unfortunate but then again, there are lots of issues with the truck that have yet to be fixed. |
I started a poll for people with civic VX's to see if we can find any patterns in the pcv check valves.
http://ecomodder.com/forum/showthrea...lve-16877.html It might take a while to get enough people answering the poll to get any useful info out of it, but I think it will be worth while in the end. |
Not sure if that poll will be particularly useful considering the OP was absolutely adamant that he and a few others did not have a PCV valve when, after forceful prodding, did in fact have one.
Forceful prodding is true. I certainly didn't believe it had one until I physically searched hard for it. I also didn't realize what it was until I cleaned it up and got it working. Otherwise I would have assumed it was just a straight union to meet the breather box.
I'm guessing his point is what I was thinking; there's a lot of information on the web that says there is no valve. It has become "true" regardless of whether or not it is. I think it is wise to have a poll, however, because if there were any differences between the years/cai-non cali models it would be good data to have. B |
