Originally Posted by redpoint5
All plug-in hybrids I'm aware of will periodically start the engine if it's not used often enough during normal driving so that the fuel eventually gets consumed. Does this iteration of the plug-in not do that also? I'd not worry about consuming fuel unless you think you wouldn't get through 1 tank in a year or so.
It does have an engine start automatically after several miles driven without the ICE starting. How many miles the manual doesn't really say. According to this dealership this person basically ran in EV mode for over a year, and the engine never started.
According to the owner's manual the gasoline engine will turn on...
1) If vehicle speed is more the 84mph.
2) When power is acceleration is needed suddenly.
3)When the temps are very hot example driven on a hill.
4)When temps are very low 14*F or lower.
5)Windshields defogger is used.
