EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   N or EOC in an automatic Tacoma? (https://ecomodder.com/forum/showthread.php/n-eoc-automatic-tacoma-24532.html)
tacopower 01-05-2013 10:11 PM
I've heard conflicting things about coasting with an automatic transmission. Will doing either of these damage the engine or transmission? why exactly does this happen? I have a 2012 toyota tacoma 4x2 automatic.
2000neon 01-05-2013 10:20 PM
I can't imagine that coasting in Neutral will hurt it, but that depends on how it reacts going back from neutral to drive, if it clunks or makes any other indication that it's not happy I wouldn't do it too much. As far as coasting with the engine off, see if the truck can be "flat towed", which means being towed with all 4 wheels on the ground. If it can't, or it doesn't specifically say that you can, I would leave the engine on.
The reason is with the rear wheels turning, so is your driveshaft and transmission, if the oil pump for your trans runs with the torque converter, you NEED to have the engine running to pump fluid to keep everything lubricated, even while coasting.
tacopower 01-05-2013 10:42 PM
Thanks. I checked the manual and it says that it can not be flat towed, which I guess is equivalent to EOC.
So if the engine is idling in N it will still be pumping (enough?) fluid for the driveshaft/transmission?
2000neon 01-05-2013 11:17 PM
Since it says not to flat tow, I would NOT do any engine off coasting.
Yes, even in neutral the torque converter and oil pump will still pump enough fluid. I don't know the exact details of your truck, but in general in the vast majority of vehicles it is fine. The torque converter is attached to the flywheel of the engine, and spins with the motor, so even in neutral it will still pump enough fluid to keep the trans lubricated. :thumbup: A little while back my old Neon (automatic trans) was having some problems and had to tow it a short distance home, but wasn't worth a tow truck, so we just flat towed it. It wasn't very far, and we were just towing at slow speeds, but what I did was put it in neutral and ran the motor to keep from hurting the transmission. It burned fuel that way but I figured it was worth it to save me any more for repairs.
mechman600 01-06-2013 11:51 AM
EOC for short distances (<1/2 mile) won't hurt even if you are not supposed to flat tow your truck.
nemo 01-06-2013 01:39 PM
This assumes the transmission is in good condition and done at low speed. Better to follow towing recommendations.
mcrews 01-06-2013 07:11 PM
As a point of safty, I would NEVER 'engine OFF coast' w/ an automatic. With a standard I'm ambivolent.
The 'trick' is Does the rpm drop to idle in neutral coast? My Infinti drops to idle, so does my Kia sportage. I think my 97 Toyota Avalon did also (that was 7 yrs ago so I'm cant say for sure)
I drove a Ford Tauras for a week and it didnot drop to idle. so there was little or no gain in mpg.
Chisel86 01-14-2013 02:31 PM
When you coast in gear (in a modern fuel injected car), it actually doesn't use any fuel at all, as the car is now pushing the engine and the computer knows this. Whereas when you coast in "N", when the engine slows to idle speed, it actually uses fuel to stay running.
This does not apply to cars with carburators and fuel pumps not controlled by an ECU.
mcrews 01-14-2013 02:38 PM
So you said (if I understand) that when IN GEAR w/ENGINE ON, NO FUEL flows to the engine when coasting down.
And At NEUTRAL COASTING enough fuel flows to idle the engine.
Need some proof on that.
Because the spark would have to be turned off also. And I just cant see that happening.
That is technology that is VERY similar to "engine off" at lights like BMW is bragging about in their commercials on the 3 series
user removed 01-14-2013 02:46 PM
Automatic transmissions require fluid pressure to function properly Most run the primary pump off the back of the torque converter which required the engine to be running. I have seen them destroyed by towing, mostly Nissans in my experience. I would not even consider coasting with the engine turned off in your Toyota, unlesss you had specific information from the manufacturer that clearly stated they would cover any warranty issues even with engine off coasting.
Why chance a rejected warranty claim that they can prove with the information stored in your ecu.
regards
Mech
nbleak21 01-14-2013 03:08 PM
Yes, it is true!
...to an extent
...on some models
...sometimes
What Chisel was referring to, is DFCO (deceleration fuel cutoff.) some makes and models implement it into the ECU, and dependent upon certain situations, it can indeed save more fuel rather then coasting in neutral.
For example: my 2003 CR-V implements DFCO during pedal off coasting in 3rd & 4th gears down to about 35mph, by engaging the TCLU (IIRC) and then resuming a normal "in gear" coast from 34mph->0mph.
Furthermore, the DFCO works all the way down to ~22mph if I disable overdrive.
This feature is great when I am wanting to use the engine as a brake instead of wearing out the pads and rotors!... But only during deceleration (to stop lights, signs, traffic congestion, etc) or maintaining speeds down a hill without the need of the throttle...
But there are many instances where neutral coasting benefits me more (slight negative grades, idle at stop lights, accelerating via gravity down hills, etc...)
Researching your engine/trans combo and use of a scan/ultra gauge or torque app, will allow you to find these values and optimize your habits accordingly!
Chisel86 01-14-2013 03:42 PM
Why would the spark have to be turned off? A spark with no fuel is just a spark and no combustion.
I believe this is also why carburated cars tend to backfire more often during deceleration because the fuel is still being supplied, but not being fully used.
pete c 01-15-2013 03:24 PM
I won't EOC an auto for a few reasons. First. it may or may not damage the tranny, so, just not worth the small fuel savings. Second is for safety. This applies particularly when in traffic. With a manual, you have an instant means of spinning up the engine, even if it doesn't start, to regain power steering/brakes. With an auto, there is a delay and what the vehicles doesn't want to restart?
Chisel86 01-16-2013 01:32 PM
Also, all your powered systems will be unavailable with the engine off, ie. power steering, power brakes, and any other computer controlled safety systems. Not safe or smart to coast with the engine off in any circumstance.
nemo 01-16-2013 06:17 PM
Not everyone has PS, PB, ABS and an Auto. They only loose one option, the ability to accelerate out of a situation with out a restart.
Chisel86 01-17-2013 11:07 AM
What I am saying is that the majority of current vehicles will have at least some systems controlled by the computer. Also, I believe that some SRS systems (air bags) will not deploy if the car is switched off, but that also depends on the car.
Basically, why would you risk your safety for the sake of saving a few pennies?
ksa8907 01-17-2013 11:32 AM
That's why most users have a kill switch so the key can stay in the on position. I understand the safety aspect, and I would never eoc in heavy traffic, but on the highway and interstate, (around here), its perfectly safe.
I currently have an auto and I do neutral coast in a few spots of my commute.
pete c 01-17-2013 01:35 PM
+1
selective EOCing a manual trans is safe and can save more than a few pennies.
