EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   Nanogenerators to power mobile devices (https://ecomodder.com/forum/showthread.php/nanogenerators-power-mobile-devices-16658.html)
vacationtime247 03-31-2011 03:23 AM
Figured this was the best place to post this. Not sure either way on this one.
VT247
io9. We come from the future.
In a few years, you may never have to recharge your phone again. Today scientists announced the first viable "nanogenerator," a tiny computer chip that gets its power from body movements like snapping fingers or - eventually - your heartbeat.
This technology, long anticipated by futurists, could replace batteries for small devices like MP3 players and mobile phones within a few years. For now, they can generate enough electricity to power a liquid crystal display and an LED. A group of researchers led by Georgia Tech's Zhong Lin Wang announced their groundbreaking discovery today at a meeting of the American Chemical Society in California. So how do these nanogenerators work, and when can you buy one?
The generator itself is a flexible computer chip that you squeeze between your fingers. The chip converts the pressure into electrical energy, which it can store in capacitors and use to power LEDs. Over the past six years, Wang and his colleagues have boosted its power output by thousands times and its voltage by 150 times - and they think this is just the beginning.
Said Wang:
This development represents a milestone toward producing portable electronics that can be powered by body movements without the use of batteries or electrical outlets. Our nanogenerators are poised to change lives in the future. Their potential is only limited by one's imagination. If we can sustain the rate of improvement, the nanogenerator may find a broad range of other applications that require more power.
He suggested its future uses would include "personal electronic devices powered by footsteps activating nanogenerators inside the sole of a shoe; implanted insulin pumps powered by a heart beat; and environmental sensors powered by nanogenerators flapping in the breeze."
According to a release about the discovery, we owe this amazing leap forward in energy generation to zinc oxide:
The key to the technology is zinc oxide (ZnO) nanowires. ZnO nanowires are piezoelectric - they can generate an electric current when strained or flexed. That movement can be virtually any body movement, such as walking, a heartbeat, or blood flowing through the body. The nanowires can also generate electricity in response to wind, rolling tires, or many other kinds of movement.
The diameter of a ZnO nanowire is so small that 500 of the wires can fit inside the width of a single human hair. Wang's group found a way to capture and combine the electrical charges from millions of the nanoscale zinc oxide wires. They also developed an efficient way to deposit the nanowires onto flexible polymer chips, each about a quarter the size of a postage stamp. Five nanogenerators stacked together produce about 1 micro Ampere output current at 3 volts - about the same voltage generated by two regular AA batteries (about 1.5 volts each).
Wang says the next step is to boost the nanogenerator's power output further, and find a manufacturer for them. He hopes to start by using them to power sensors, but believes that other uses will come quickly afterwards. You're going to see these tiny generators in stores within 5 years, he predicts. Get ready for the plugless, fossil-fuel-free future!
via the American Chemical Society
Christ 03-31-2011 10:18 AM
So they're going to put these in tires... And when you drive your electric car, you'll really be charging it?
Joenavy85 03-31-2011 10:43 AM
these are legit, but the energy they put out is insufficient to do much more than power a watch like the post said. you would need a rediculous amount of these things to even remotely help your vehicle. in the future they may be able to make them with a higher output, but you would still need a large number of them to really do anything.
NOTE: 1 micro ampere = 1 millionth of an amp
Christ 03-31-2011 10:46 AM
For the record, I was being facetious.
I'm sure someone will think of it, though... Give it time. ;)
Frank Lee 03-31-2011 11:01 AM
Re: tire powered devices: Humanity sure could use these:
SIT | Self Inflating Tire
because checking and inflating tires is such an onerous, technically demanding task.
jamesqf 03-31-2011 12:23 PM
Not exactly a new idea. Ever hear of the self-winding watch? Automatic watch - Wikipedia, the free encyclopedia
rmay635703 03-31-2011 07:30 PM
Yes they will help automotive companies prevent the very dangerous practice of improving your fuel economy by disregarding their safe 20psi placard pressures.
