EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Nanoparticles in fuel could boost aircraft efficiency (https://ecomodder.com/forum/showthread.php/nanoparticles-fuel-could-boost-aircraft-efficiency-41155.html)
Xist 10-19-2023 05:02 PM
I have had this open for a few months, but whenever I saw it, I really needed to be doing something else.
Grad school! :D
https://physicsworld.com/a/nanoparti...ft-efficiency/
freebeard 10-19-2023 05:34 PM
So by adding burnt carbon (graphene oxide) they reduce carbon emissions?
Here is my oldest open tab. uf-cise-surflab.github.io/blender-polyhedral-splines-web/
Polyhedral Splines
Introduction
Polyhedral splines is a Blender add-on that converts quad-dominant meshes into B-spline patches. This enables artists to edit spline surfaces in real-time via the existing polyhedral modeling capabilities of Blender.
https://uf-cise-surflab.github.io/bl...or_patches.jpg
redpoint5 10-19-2023 06:05 PM
I just switched from Chrome to Brave, so only 19 open tabs now; none older than a week.
Piotrsko 10-20-2023 11:11 AM
BACK on topic..... wonder if non carbon nano particles would increase atomization. Perhaps the philosophers stone? Suspect they picked carbon due to availability.
No extra open tabs; bookmarks
freebeard 10-20-2023 06:23 PM
https://en.wikipedia.org › wiki › Acetone
Acetone - Wikipedia
Acetone (2-propanone or dimethyl ketone) is an organic compound with the formula (CH 3) 2 CO. It is the simplest and smallest ketone (>C=O).It is a colorless, highly volatile and flammable liquid with a characteristic pungent odor.. Acetone is miscible with water and serves as an important organic solvent
Do a search on "acetone fuel additive".
Piotrsko 10-21-2023 10:24 AM
BTDT, MO. There are other compositions, some work most don't at least as far as mileage increase. Co at tailpipe too difficult to test for on freeway.
