EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   NASA: thumbs down on VSAERO shape factor H (https://ecomodder.com/forum/showthread.php/nasa-thumbs-down-vsaero-shape-factor-h-40612.html)
aerohead 12-01-2022 12:44 PM
If this link succeeds, it's an empirical evaluation by NASA, to validate the capability to predict the flow separation location on a body, based upon the Electronic Data System's VSAERO, mentioned by Goro Tamai, in his book, The Leading Edge.
The title of the thread foreshadows their results.
https://ntrs.nasa.gov/api/citations/...9890010727.pdf
freebeard 12-01-2022 05:53 PM
TLDR;
Figure 27 appears to imply an attached wake from an integrated half-body will lift itself clear of the larger surface due to it's internal dynamics. Correct?
aerohead 12-08-2022 12:47 PM
' TLDR... Figure 27'
Originally Posted by freebeard (Post 677537)
TLDR;
Can you tell us where that comes from? I haven't a clue.
freebeard 12-08-2022 04:25 PM
It's the second figure on page 30 of the PDF you linked to.
aerohead 12-08-2022 04:43 PM
Fig 27, page-30
1) I cannot associate that structure with anything related to an automobile.
2) There is no streamlined half-body depicted anywhere.
3) Half-bodies aren't ever 'ON' surfaces.
4) In fluid mechanics, there's no such thing as 'internal dynamics.'
5) Half-bodies do not have wakes. They're 'streamlined', incapable of generating a wake. Just a bit of TBL sloughing off the trailing edges.
kach22i 12-10-2022 09:38 AM
The rotor hub has such a shallow slope or shape, yet so much turbulence.
Must be a tough environment with those large helicopter rotors swirling around.
Not the results I would have expected.
I guess this makes Frisbees and flying saucers candidates for the non-aerodynamic thread.
