EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   NASCAR Speedpark - Electric Go-karts (https://ecomodder.com/forum/showthread.php/nascar-speedpark-electric-go-karts-8800.html)
Who 06-16-2009 01:57 AM
I took my one son to the NASCAR theme park just north of Toronto and found it rather humorous that the fast karts were electric. The gas powered outdoor karts were over governed and idled nearly all day long with fumes that would make a car from the 50s seem right at home.
In comparison, there were electric go-karts inside on an under over figure 8 track. They used a very large starter motor - forgot the details of the motor - sorry - connected by a toothed rubber belt to the axle. The back tires were fairly skinny for a gokart and just behind the front tires and in front of the rear tires were 12 volt deep cycle batteries - the ones that look like enclosed 6-packs.
The cool part was the charger. When the cars come back from the pit, the center surface between the tires was a raised surface and they stop the cars so that they are strategically placed above two flush metal plates beside one other measuring about 6" wide and a foot long that charge the batteries between races. The races would run around 6 minutes and you could feel them depleting by then. Great torque though... I'm over 230 and had no problems keeping the far lighter weight competitors humble! :thumbup:
almightybmw 06-17-2009 01:40 AM
sounds neat. I have an old starter from a V8, would love to turn it into something fun.
Something to note, an equiv sized rotary motor makes around 40hp, vs the piston's 5-10hp. Downside, it's thirsty.
eco_generator 06-18-2009 01:44 AM
Sounds fun, I'd like to try one out!
myroona 05-02-2012 03:20 AM
I have been to NASCAR theme park few times ago with my older son and had great time! I will really enjoy to repeat this experience and i'm sure we will go there with all familybuy go kartsoon.
myroona 05-05-2012 05:50 PM
feedback
Coming back to check if someone added something new...
