EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Natural Gas Conversion Kits for Gasoline Fuel Injected Vehicles (https://ecomodder.com/forum/showthread.php/natural-gas-conversion-kits-gasoline-fuel-injected-vehicles-20996.html)
Xringer 03-15-2012 12:47 AM
DudaDiesel Alternative Energy has them on Ebay..
4 Cylinder CNG Natural Gas Conversion Kit for Gasoline Fuel Injected Vehicles | eBay
But, they aren't cheap.. :eek:
Interesting product.. Now that gasoline is getting to be a bit steep.. :mad:
UFO 03-15-2012 01:12 AM
Be wary, this statement on the listing is not true:
The existing gasoline system is used for cold startup and the system switches to CNG when warm enough for heating the liquid CNG to make it into a gas.
Liquid CNG? Really?
And this "kit" does not include a tank. No mention of operating pressure either.
euromodder 03-15-2012 07:36 PM
What's not true about it ?
Evaporating a cooled liquified gas will take some heat input as the evaporation process draws considerable heat from its surroundings - freezing any water in the air.
UFO 03-15-2012 07:59 PM
CNG = Compressed Natural Gas. It's not liquid in the tank, where in the injection process do you think it becomes liquid?
Never. Especially since there is no tank or regulator included, there is no way to run LNG (Liquified Natural Gas), and you need cryogenics to install it.
BTW, most CNG applications are about 3000 psi. This is not your backyard BBQ propane tank we are talking about. From wiki....
CNG's volumetric energy density is estimated to be 42% of liquefied natural gas's (because it is not liquefied), and 25% of diesel's.[4]
Xringer 03-15-2012 08:30 PM
BBQ anyone? :)
Here's the Propane kits..
propane | biodiesel supplies
The manual.. http://www.dudadiesel.com/files/prop...panemanual.pdf
http://en.wikipedia.org/wiki/Liquefied_petroleum_gas
