Old 12-17-2013, 10:16 PM   #1 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
1991 Tercel Weird Lighting Issue
My '91 Tercel does something really annoying - when you put the turn signals on, the high beams stay on with them. The high beams don't flash, they just come on as soon as you move the signal arm far enough to make the signals work, and stay on until the arm is back to center. From what I can tell in parts catalogs, the signal switch is different from the dimmer switch, but they are right on top of one another. Anyone ever seen this before, and know what could be causing it? Thanks.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 12-18-2013, 09:17 PM   #2 (permalink)
Maybe relay or grounding issue?
