EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Need help installing mpguino on 95 tracker (https://ecomodder.com/forum/showthread.php/need-help-installing-mpguino-95-tracker-25176.html)
Desmondghostrider 03-09-2013 06:02 PM
Hey guys
I have a 2 door 4x4 soft top 16valve 1995 geo tracker
Im trying to install a mpguino.
Ive connected power and negative.
For the vss I connected to a yellow and silver wire I was told is the vss.
For the injector I connected it to a blue wire coming off the first fuel injector. Theres one per cyl so Im not sure if this is correct.
The mpguino came programed for a 94 auto geo metro but I decide to put it in the tracker instead. When installing it I accidentally pressed the buttons and messed up the settings that it came with.
Its reading that its gettig 999 mpg.
Anyone have any ideas as to if its connected correctly and what each of the settig is set on?
Thanks!
Desmondghostrider 03-10-2013 12:07 PM
Anyone?
Desmondghostrider 03-10-2013 07:46 PM
Bump
Cobb 03-10-2013 08:29 PM
Ive never let knowledge stand in the way of joining a good topic. :eek:
I am guessing since it is reading 999 for mpg that means its not getting an injector signal, but the other three, power,ground and vss is working.
Desmondghostrider 03-11-2013 01:49 AM
Ok im still having a bit of trouble. I switched the inj wire to the other wire that comes off it and the values started changing. Now when im moving the mpg slowly rises up further and further till it gets to 999. Heres my values if you see a problem please let me know.
Vss pulse/ mile : 4000
Microsec / gallon : 3449470563
Pulses/2 : 3
Timeout(microsec) 300000000
Tank gal : 11100
Injector delayuS : 500
Weight: 2189
Scratchpad : 0
Vss delay ms : 2
InjTrg 0-dn 1-up : 0
Metric : 0
razor02097 03-11-2013 07:16 AM
The VSS wire is a yellow wire A7 and injector 1 is a red wire B11. Both can be found on the two connectors going to the computer under the dash.
click => http://i108.photobucket.com/albums/n...-49-32_366.jpg
Also... Check the following thread if you get the dreaded switch bounce at freeway speeds.
http://ecomodder.com/forum/showthrea...ino-25144.html
Desmondghostrider 03-12-2013 07:47 PM
Ok I got the wiring all where it should be but it just hops all around. It will go from 20 to 80 and all over the place.
Do I have all my settings correct?
Desmondghostrider 03-12-2013 07:48 PM
I bought this mpguino from a guy on geometrofroum and he said that he added something that kept the signal from bouncing.
razor02097 03-13-2013 08:09 AM
What hops around? The speed? MPG?
Set your PPM to 8200 then follow the calibration procedure here...
Mpguino calibration - EcoModder
If you scroll over to a screen that shows speed check to see if the speed is erratic. If it is you could have interference or may need a switch debounce circuit. Look here...
Desmondghostrider 03-13-2013 10:54 AM
I got the speed set and running smooth but mpg is still way off. Im working on setting the tank correctly. Almost got it :)
razor02097 03-13-2013 11:56 AM
Yeah the PPM for the Geo metro is like 4700 and the tracker about 8400 IIRC... That will give you way high false MPG numbers if you still have the PPM set low.
