need a hyper lesson
I finally got a OBD and connected it via Bluetooth to my Tablet. driving my regular commute today was a new experience. I always assumed that a car driving at 2000rpm was burning the same amount of fuel whenever it was at 2000 rpm. now I see that rpm has nothing to do with fuel consumption. Iwas amazed at Tbe jump in fuel consumption when climbing hills, and disappointed b y how little a difference coasting downhill or driving downhill actually make.
I am wondering now if I should be accelerating down hills and coasting as much as possible uphill. my commute is constant ascent and descent one after another with very little flat ground. |
I generally let the speed increase and then bleed it off climbing the hill. The extent to which you do this depends on the max elevation of the hills. You could also try coasting downhill even if your speed increases. Think of the roller coaster and how it climbs and descends without any additional power. The closer you can come to that type of movement, the less fuel you will use.
What you are experiencing is changes in load independent of throttle position. Every hill gives you the opportunity to use the mass of your vehicle to store energy. While the mileage climbing the hill may seem terrible, remember you can coast downhill with the engine idling or even shut off (if its a manual transmission) and use no fuel whatsoever going downhill. regards Mech |
I know the average fuel use is the one I should focus on. I'll keep working on my driving. thanks.
another thing I have noticed is that 105kmh seems to be more efficient than 90. even neutral coasting gets more efficiency at higher speed. I need more time to actually understand y OBD but it seems That way to me.
In short, the amount of fuel your engine requires depends not only on rpms, but also on load (how much of its power-producing potential is needed at given rpm). Each engine has its own BSFC chart, ie how much fuel is used per unit of energy, usually in g/kWh, depending on engine speed and load. Here is an example: Notice the little '250 island' in the middle? That's where you want to keep that engine as much as possible, since it uses the least amount of fuel for what it's doing. In other words, that engine is most efficient around 2600-3400 rpm and 70% load. The "sweet spot" is different for each engine, but it's usually around the max torque rpm and 60%-90% of load. Load depends on more than just how much your gas pedal is pressed, so something like a ScanGauge is worth its weight in gold if you're hoping to keep your engine in its most efficient area. A BSFC chart, like the one above, for your specific engine is also very valuable, but often hard to find. See this thread for more info. Quote:
All cars have different points of efficiency over the RPM range. Using a computer to see exactly which RPM amount gives you the most efficiency is the key. If I were the OP I would use pulse and glide over the terrain. Accelerate briskly going up the hills and then turn the engine off and coast down the hill until you reach the bottom or near. You will then have to accelerate quickly to your target speed up the next hill and so on. This may seem to be bad for mpg because of the acceleration up hills but depending on your coasting distances and speed range the average mpg over your trip will be much higher than just driving at a steady speed. |
When driving on hills, I try to avoid situation where car has to pull or 'drag' car up to hill, instead I try to gain speed from downhill that will carry me up, usually it is possible to do this by coasting at neutral.
Usually speed decreases to 60kph on uphill, some hills even lower, but at downhill speed is gained plenty more than enough. Goal of 'game' is to allow speed to decrease enough that when you coast downhill police will not give you ticket. However if there are other cars behind, then this is not quite possible to do as they (other drivers behind you) will react emotionally and pass when it is not safe etc. 105km/h can be more efficient only if gearing is such that one is well below powerband at 90km/h, but with better gearing it might be possible to get better economy at slower speed as aero drag increases lot when going from 90km/h to 105km/h, so smaller diameter tires might be worth to consider. I know that my winter tires are too large diameter for hilly ground near me, that is part reason why I got so horrible fuel economy over winter. |
Er, smaller tires better fuel economy? I think it's the other way around...
The reason 90 could be worse than 105 is because despite the extra power required, your engine efficiency could be going up a lot from 90 to 105, possibly enough to provide a net benefit. A simplified way of thinking about it is the engine has some amount of friction that you can't remove, and higher load only increases this friction by a relatively small amount. If you're only asking the engine to give you barely any torque, then most of the power made is actually going to overcome the engine's friction. If you ask the engine for say twice the torque, then you don't need twice the fuel, because most of the fuel was going to waste in the first place. If enough fuel was going to waste in the first place, then it's possible that the increased load could improve your mpgs. |
On level ground bigger wheels are really helping my economy, but not when there is hills. As was posted previously, one can see that 250 area, with bigger wheels it is not possible stay in there at all on hilly area. (We have warning signs of 7% hills here for example). With diesels at least higher load increases fuel usage a lot, you will start to get black smoke from end of tailpipe telling there is lot of unburnt fuel, efficiency is not optimal, better to stay at maximum torque with smaller wheels, better speed on 5th than with bigger wheels and 4th at maximum torque rpm so economy is better too. Below 1800rpm for me is where there is nothing happening in motor, even I push pedal to floor there is very little happening except that black cloud and above 2200 boost enrichment adds lot of fuel, so that is also causing issue in my case, speed with bigger wheels 5th gear and max torque (around 2000) would be illegal by expensive amount, so that is also why bigger wheels will cause more fuel consumption. Perfectly possible, such has happened many times, there is certain maximum that is going to be optimal, go above and there is impact to economy, go smaller and again there is impact to economy, finding that optimal is not always easy. |
Ah I see you're talking about a turbo diesel. I'm not too clear on how different a diesel's powerband looks, but if you shift down, it doesn't hurt economy as long as you're operating the engine near peak efficiency right? Shifting down reduces the load requirement anyways.
I guess the turbocharger + diesel combination changes the rules a little since diesels pass a larger volume of air through at low load than gas engines, and would build up boost fairly quickly. I suppose I didn't think of the fact that higher rpm on a diesel means a lot more gas going through the turbine. |
I think that lower gear means less speed, which in turn gives less distance for similar rpm and load, thus it could be same consumption if larger wheels would give same rpm and load with 4th gear than smaller wheels with 5th gear, but it would mean that speed should be relatively similar too, I guess. With my case there is only difference of bit over 100rpm with tires, but it is enough to cause too much load on steep hills. Going bit faster and pushing it more would give more power, but with price of boost and very much higher consumption. I think that petrol cars get away bit better with this, also NA diesels to some extent as higher rpm is not causing boost which is reason for high increase of consumption. Old tech turbo diesel is bit problematic in there, all mechanical so boost enrichment is made to be safe for all situations, so it is relatively lot of enrichment. I have also observed bit of same with modern diesel with fuel computer onboard, even engine has low end torque quite a bit, using that torque puts really huge numbers to screen, better use lower loads and more rpm. So I try to drive so that I don't need to shift down, which seem to be working well, only few hills where I need to shift down as I also try to avoid using high loads, makes driving rather interesting with only 400rpm to play with :D Example of boost up would be like this; I drive at 0 boost on 5th gear, I shift 4th, continue at same speed and I have 0.2bar boost, if I accelerate even little it climbs easily up from there and this is not even VNT which would boost much earlier. 2500rpm is boosting 0.1bar when engine braking. That is indeed because diesel has no throttle butterfly, it is wide open constantly. One thing this topic made me think is that it is really different techniques that different vehicles require and it is same as with aero, there is no single way or single method to cover all cars or even all diesels, there are too many variables to make generalizations I believe. Only thing is certain that all cars can be made to use less fuel, methods might vary. My experience is mostly from fully mechanical turbo diesel with small turbo, all applies of course to that, maybe some other kind of vehicle that has similar characteristics, variables, but certainly does not apply to all cars. |
my tires are a bit larger than OEM size. my speedo shows 100kmh when I am actually travelling 103 by GPS. I hadn't thought of this before. if my speedo is off, my odometer is off too! does it mean I am actually getting less or more economy than I am calculating!
a wheel correction tool also . calculated my mileage to be off by 3percent .
