Old 07-14-2010, 12:07 PM   #1 (permalink)
Question What's the minimum wire gauge required for the MPGuino?
What's the minimum wire gauge required for 4 input cables/pins on the MPGuino?
What is the maximum amperage that the lines some be handling?
I found a post where DCB referenced the center connector in this pic: http://media.digikey.com/photos/Assm...s/AK521-.2.jpg
I believe that the cables pictured are 18 AWG cables.
All I found at radio shack was 20' 24 AWG 4 Solid Conductor Intercom Wire:
20' 24AWG 4 Solid Conductor Intercom Wire - RadioShack.com
It's small and solid core...
I saw a couple of pics of installs that seemed to have possibly used cell phone charging cables. Looks like fairly small wires in a common sheath, the coiling made me think of a cell phone car charger.
I am considering using a 4-flat 14 AWG trailer wire harness extension.
Like this: Amazon.com: Hopkins 47115 4 Wire Flat Extension Harness (48")
I would cut the extension cable, wiring one cut side into the MPGuino and the other cut side into the various sources (with added cable, if required).
That would provide for a second disconnection point, not sure if it would really be needed.
But, isn't 14 AWG too excessive for the requirements?
I like the idea of re-purposing an old phone car charger, but am concerning about the rated load. Based on the pics that I have seen, it does appear capable, but I would guess phone chargers are somewhere around 18-22 AWG.
What is the cable AWG recommendation?
Old 07-14-2010, 12:15 PM   #2 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Lots of people use telephone cord wires. There are 4 of them, and they can handle the current and voltage... AND they are cheap (dollar stores) / free (junk drawer) for most people. I don't know how much smaller you can go, but the phone lines are small, and already bundled for you.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
OBD MPGuino gauge jmonroe OpenGauge / MPGuino FE computer 855 03-16-2018 08:47 PM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 80 02-18-2015 12:58 PM
MPGuino install on 97 Honda Civic DX steffen707 OpenGauge / MPGuino FE computer 10 04-26-2013 12:17 AM
MPGuino rebooting and freezing also... Power issue? tygertec OpenGauge / MPGuino FE computer 28 04-17-2011 04:05 PM
