EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Need mpg tricks for Aspire97 (https://ecomodder.com/forum/showthread.php/need-mpg-tricks-aspire97-19138.html)
MPG Hunter 10-13-2011 09:10 PM
Gettin 28mpg city A/C on,flooring at every light(JJ),I like starting fast at the light but that can change,Need some ideas, other than slowing down ,on 1.3L mazda motors.EGGBEATER-;P-American rice burner!
Daox 10-13-2011 10:58 PM
Here are 100+ ideas: 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Here are 65+ more: 65+ Vehicle modifications for better fuel economy - EcoModder.com
Good luck. :)
MPG Hunter 10-14-2011 11:35 PM
Thanx for the car specific advice.
Wow,those links look a lot like the general topic ones on the home page,huh.O-well i thank ya kindly sir!:thumbup:
brucepick 10-15-2011 01:10 PM
Well - - - -
if you want different results from what you've been getting, you'll need to change something that you've been doing. Take your pick on what you want to change.
Come to think of it, my tire pressure tip in signature below isn't a bad idea, for starters. Personally, I start at the "sidewall max" pressure and work from there. I pay no attention to the door sticker; in my humble opinion it's written primarily for butt comfort and tire sales.
MPGranger 10-15-2011 02:26 PM
about your acceleration habits, look into the BSFC charts. They're basically telling you what RPM and engine load is the most efficient.
And slowing down to at least the speed limit will be helpful. The air drag formula uses speed squared. So 50MPH squared is 2500 and 70MPH squared is 4900. That's almost double the drag!
