Old 03-19-2008, 08:45 PM   #1 (permalink)
LibbyMetro's Avatar
Da' Honda - '98 Honda Civic EX
90 day: 36.79 mpg (US)
1995 K1500
hey guys my pickup is acting up , for the past couple months when gas is applied, and only when gas is applied i have a loud humming noise that smoothes out the faster i go, but doesnt start until i hit 25 mph no matter what gear im in , as soon as i let of the gas it goes away, front cv shafts are good, u joints are good, rear pinion bearing has no play in it. Im stumped, help would be appreciatted
Old 03-19-2008, 08:52 PM   #2 (permalink)
Red
Red's Avatar
Driveshaft CV ball?
Old 03-19-2008, 09:25 PM   #3 (permalink)
LibbyMetro's Avatar
ball? what do you mean ?
Old 03-19-2008, 09:38 PM   #4 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Speculations... (since it isn't engine speed or specific-gear dependent)
In addition to Red's suggestion...
Tire wear
Driveshaft out-of-balance
How's the rear diff gear oil?
Have you tried the 4-wheel drive engage/disengage?
Any more info on the problem -- does it do it in neutral, things like that?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 03-19-2008, 09:49 PM   #5 (permalink)
LibbyMetro's Avatar
tires are nearly new 33 inch BFG all terrains, with no unusual tire wear , all the weights that were on the shaft are still on , rear diff oil is ful both front and rear, it not in the 4 wheel drive already tested that, somewhere in the tranny on back
Old 03-19-2008, 09:53 PM   #6 (permalink)
H4MM3R's Avatar
How many miles on your truck. Your fuel pump might be going bad.
Old 03-19-2008, 10:15 PM   #7 (permalink)
LibbyMetro's Avatar
its not the fuel pump, been checked, its in the driveline , 216,000 on the truck 55,000 on the tranny, tranny flushed 4000 ago, goes in for pitman arm , idler arm , and alignment tommorow
Old 03-19-2008, 10:17 PM   #8 (permalink)
H4MM3R's Avatar
exhaust leak?
Old 03-19-2008, 10:25 PM   #9 (permalink)
LibbyMetro's Avatar
lol no , its in the driveline i can feel the humm in my pedal
Old 03-19-2008, 10:47 PM   #10 (permalink)
H4MM3R's Avatar
Put an extra pair of socks on.
Newcomer - 1995 Ford Aspire Ethanol cbergeron Introductions 20 07-09-2008 11:52 PM
