need some advice to up my mpgs
been lurking around for awhile just reading and make some posts.
its time for me to go all out on my love for mpg. i have a 94 5 sp geo metro coupe any advice will be considered |
First if you didn't already read the thread 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com. That has everything from the mild to wild fe improving ideas. IMHO, when starting focus on driving techniques initially, because they're basically free. The only exception to this is basic maintenance, if your car has never had a tune-up and your tire pressure hasn't been checked since the tires were installed you should get onto those pronto. Also, keep in mind that just because somebody got great results out of a mod doesn't mean you will. Some mods give better results with certain vehicles or driving situations(e.g. aero mods will give better results if you do a lot of highway than city.)
Go slow, coast as much as possible, and stop as infrequently as possible. 55 mph roads are better than 65 mph roads, and 35 mph roads are even better.
i used to own a civic hybrid.
the user manual said: don't use the accelerator or brakes. it really did. |
Sometimes something gets lost in translation... :rolleyes: :D |
coast and easy on the accelerator.
I have gotten great results by dwl and coasting as often as I can. I accomplised nearly a 5 mpg increase by those techniques alone. No Jackrabit starts from stoplights or stopsigns.....you'll get there eventually anyway. No need to rush.
I have found just seeing the gallons/hour fuel flow on the MPGuino dramatically changes how I drive. I tend to accelerate more slowly by limiting the fuelflow I see. That alone is helping quite a bit, even with city driving. The link above will give you a lot of advice. I agree, start with the mild costs nothing stuff... My truck will be losing another 100 pounds by this summer if I have my way.
Vacuum gauge is $40, and/or the MPGuino is $55... either will pay for itself fast. Like they said above, adjusting your driving will have the biggest effect. Timing stoplights helps too (try to coast towards the red til you get a green). Good luck in your pursuits, there's a lot of good advice on here.
well there is alot of things you can do but driving is always the most effective. After that I would probably start with a grille block, full or not. Moon disks, mirror delete, kammback, theres alot of different ways to go.
What motor do you have? 3 cylinder or 4? |
I find driving 45 Mph in my Honda Accord really helps increase MPG.
Do you use a Scan Gauge II on a daily basis now? |
Considering his car is a 94, a SGII won't help him much.
At least he's got a good fuel efficient car to play with *jealousy erupting* |
