Old 12-05-2008, 07:31 PM   #1 (permalink)
Preventing brake rotor rust
Once upon a time, MetroMPG wondered how to prevent brake rotor rust from long-term non-use (musta been on "another" forum as the search turned up nothing here).
Well here ya go. The local car guy for the paper says this:
"If you're concerned about some corrosion on the brake rotors, you can spray them with a light aerosol lubricant. This will dissipate with the first applications of the brakes when the vehicle is put back in service."
A few easy steps keep vehicle safe in storage
I assume he means WD-40?
Anyway, I was taught that petrol-products in contact with brake pads and shoes was a no-no, so I don't know if I'll run out and try this... but there it is. (Maybe I'll do one rotor and see what happens).
Old 12-05-2008, 08:48 PM   #2 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Doesnt the rust do the same thing after one application of the brakes?
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 12-05-2008, 09:37 PM   #3 (permalink)
Yeah, that's all I've ever done.
Old 12-05-2008, 11:30 PM   #4 (permalink)
Red
Red's Avatar
Dunno, I'm a fan of letting the pads do the cleaning rather than getting oil on my breaks
Old 12-06-2008, 12:59 AM   #5 (permalink)
Yeah, lubricating the brakes seems sort of counterproductive, ya know?
Old 12-06-2008, 01:07 AM   #6 (permalink)
If the lube is indeed light enough to evaporate off when the brakes generate some heat upon first use, I can see where that would work.
Right now my truck has axle seal problems and the brake shoes are oil soaked. They still work, just not as good. And when I replace those seals (probably next spring) I plan on hitting those shoes with brake cleaner instead of replacing them.
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 07:35 PM
reducing drum brake drag Gregte DIY / How-to 46 10-28-2014 10:21 PM
4th brake light and Rear fog light. Sean T. Off-Topic Tech 10 11-27-2008 12:29 AM
Lightweight Brake Rotors and Flywheel Raysp30 Off-Topic Tech 8 08-20-2008 11:51 PM
DIY Needed - adjusting parking brake pull Yaristock DIY / How-to 22 04-17-2008 09:51 AM
