Negawatts for EV's
Negawatts for EV’s
We have been studying water heaters recently so we can be prepared for the time coming soon when our current propane water heater needs replacing. We want to switch over to an electric water heater at that time, so we can reduce our carbon footprint, because we have grid tie solar panels. While this is doable, we will have to hire an electrician to wire up a 240 volt supply line in our water heater closet. It pained me however to learn that an electric water heater would cost us about an extra $120 a year or $10 a month to operate. In looking around You Tube for videos on water heater choices and I ran across the Heat Pump Water Heater which I had not been aware of before. Heat Pumps grab heat out of the air and pump it to a new location which is to water in a tank in this instance. The output from this process is refrigerated air in this instance. Heat pump water heaters like this are amazingly efficient and in this case can save you up to 3.5 to 1 as compared to a standard resistance style electric water heater. (Note here, the Heat Pump Water Heater only requires 240 volts for the backup heating elements which you can turn off. A heat pump water heater has slower recovery times, which is not a real concern given our use patterns, so we could possibly even leave the backup elements on if we liked. The fact that this unit is a 50 gallon model will help with this recovery issue.) Our current propane water heater has a 40 gallon tank and uses approximately 100 gallons of propane a year costing us approximately $243. An electric resistance style tank water heater would as much as $322 a year which would increase our monthly cash flow out for energy by $6.58. While this isn’t that bad, it would use up valuable Photovoltaic Panel Array electrical production which we would like to minimize. In about 20 months we will be switching from a Plug in Hybrid Electric Vehicle (PHEV) to a Battery Electric Vehicle (BEV) and we would like to conserve as much electrical production from our solar panels as we can to charge our new vehicle. A new water heater that uses 2,666 kWh’s a year is far from ideal in this instance, even if it were reducing our carbon footprint. I was excited to learn about Heat Pump Water Heaters as the potential is there to provide our water heating needs for as little as $92 a year using a 50 gallon model. They do cost more to purchase up front, about $800 more. From day one we would have more spare solar power to recharge our electric car so it would be really good investment for us. I ran the numbers so I will present them here in a truncated form. We shall call the Propane model a PWH, while a Standard electric model shall be labeled as a SEWH. The Heat Pump model we shall label as an HPWH. The cost to install a 240 volt power supply for either of the new water heaters we shall assume to be $300. All my calculations are based on our use patterns and not the energy sticker that comes with the units. I just used a 80% factor to adjust these energy sticker numbers. Cost to buy a PWH $400 plus a $100 installation cost, a SEWH is $500 plus a $300 installation cost, and a HPWH is $1,300 plus a $300 installation cost. The cost total is for a PWH $500, a EWH $800, and a HPWH $1,600. As you can see I am starting out $800 in the hole over my second new option over a standard electric water heater. The cost to operate is where the return on investment (ROI) resides. The $320 per year of electrical operating cost (at 12 cents a kWh) for a SEWH adds up to a total cost of $2,088 by year four. The HPWH cost of $92 a year brings its total to $1,968 by year four so the lines cross sometime just after year three. After six years I will have saved enough to surpass the cost to buy, install, and operate a propane water heater replacement of the unit I have now. The figures for year seven are for a PWH $2,250 versus $2,244 for a HPWH so the ROI is close to seven years in this instance. The choice of a Propane WH doesn’t reduce my carbon footprint however. Better still the yearly electric consumption of only 766 kWh’s per year saves us a staggering 2,666 kWh’s – 766 kWh’s = 1,900 kWh over the more costly alternative. The question is just how many miles can you run an electric car like the Tesla Model 3 that we are going to buying in the year 2020? The answer is quite a lot, more than you would think. A Tesla Model 3 has a rated efficiency of 243 watt hours per mile. With a 90% charging efficiency 1,900 x .9 = 1,710 kWh’s a year is left over for getting the power into the Tesla Model 3 battery pack. Hence 1,710 kWh/.243 kWh = 7,037 miles, while we drive on average 15,000 miles per year in our current PHEV. This amounts to 15,000/7,037 = 46.9%, so let’s say 47% of our driving can be from electrical savings from our new Heat Pump Water Heater. This is the very definition of a “Negawatt” (that is electric savings acquired through an applied efficiency that can be used for other purposes). But wait, there is more, we get cold air from the HPWH we can vent into our living room in the summer when we are running the central air conditioning. The rest of the year we can just vent the cold air into the closet space where there is an outside air supply duct. Our propane fired water heater has not given out yet, but we now have a plan. Most of the time people end up scrambling for a replacement water heater when suddenly they do not have any hot water, because their water heater has stopped working, or it is leaking. This was our situation the last time this happened. We are looking towards buying a new (or used?) Tesla Model 3 in the late fall of 2020 when we have paid off our Ford F-150 XLT 4x4 truck that we use to tow our 5th wheel and other truck duties . We mostly drive our PHEV now, and just drive the truck enough to keep it in good operating shape. We can sell our Ford C-Max Energi on, as we will no longer be under water with it at that time, after four years of payments. When our current water heater begins to fail or fails on us is anyone’s guess. A Tesla Model 3 will eliminate the gasoline we currently use for driving the PHEV roughly half the time. The new water heater when we need to install it will eliminate the propane we currently use to heat water. We will be reducing our gasoline consumption by 209 gallons a year or 209 x 19.6 = 4,107 pounds of CO2 a year. The elimination of 100 gallons of propane per year will add up to 1,263 pounds of CO2 removed from our footprint. Together they add up to 2.68 tones. This will be quite a coup, as both of these duties (transportation and water heating) will become solar powered for at least for eight months of the year, without the installation of additional solar panels to our 5,100 watt grid tie system. We looked into an eight panel addition to Photovoltaic Array about three years ago and it would have cost us $12,500. This proposed addition of an energy saving heat pump water heat looks like our best bang for the buck until such a time as we can afford to expand our solar array. We will want to add more power generating capability to cover the air conditioning season which is the only time our electric bill goes negative at some point in the future. In the summer we currently do not receive a stipend from the electric company because our array doesn’t generate enough power to cover the increased consumption at that time. This is why installing Negawatts is such an important concept, and is of primary importance until such a time as we can expand the size of the array. Having solar power has reduced our carbon footprint for most of the year. This will continue to be true even with the addition of full BEV and switching our water heating to electricity to eliminate the current fossil fuel powered model. This scenario as I have outlined it will be a win, win, win in several ways and as Martha Stewart might say (“And that is a good thing”). |
Seems a solar water heater would be the most cost effective system in NM, if nothing else but to preheat before entering whatever WH used.
solar water heater?
You are better off using PV electricity directly to heat water then you are using thermal solar because of all the freeze protection and complexity of the system. The numbers speak for themselves on this one and heat pumps are pretty sweet.
I got a slightly used one for $360, it uses 240v power.
8 panels for $12,000 what the heck? That doesn't make any sense. What size panels? The biggest ones I have seen are around 450 watts. |
Just my two cents:
I live in Czech Republic, middle of Europe. Most relevant is it is an Dfb type climate (see here: https://en.wikipedia.org/wiki/Humid_continental_climate) We have in average 20-25 degree Celsius in summer and -5 - 0 degree Celsius in winter. 1500 hours of sunshine annually in average. Even in these conditions, when I did research for my parents house (2 person), solar heaters pay-off time was 8 years, comparable to air-water heat pump. Now I live in appartment house heated by air-water type heat pump. Since I moved we already changed our heat pump compressor once. According to technician who changed it its ifespan is 8-12 years. Add bi-annual inspection for coolant leaks, while solar heater is almost "build and forget" type. More: Below -5 Celsius is our heat pump basically unusable due freeze buildup (spending too much energy in self-defrost cycle), and during summer is overkill (you can heat water just with garden hose lying on your roof). Adding complexity with solar heaters is nonsense - you add complexity in both cases. Heat pumps are cool and in, for sure, but I agree with redpoint5. Solar heaters are imho more cost-effective. |
Most solar water heaters are indirect systems using antifreeze in their collector loop.
If you do use a fancy glycol system so it doesn't freeze then it will just get smashed by hail. Those fragile glass tubes won't last in newmexico.
Glass tubes???? Like a cars radiator?
I upgraded to a heatpump water heater 2.5 years ago. Saves me over $200/year on electricity over my old electric unit. Cost an extra $500 to install.
Good, short payback And it'll still have over 7 years on the warranty after the payback point. |
HPWH makes sense to me for hot climates where the cool output can be directed indoors.
Don't think it makes sense in my cooler climate where AC is needed for maybe 10 days out of the year and natural gas is extremely cheap. |
Good for you, but I live in the desert southwest USA and can expect better performance. I don't but the annual inspection or the eight year story as it sounds anecdotal to me.
I was expecting more like a 4 year pay back for mine.
I'm replacing my 15yr old electric for a gas heater soon. Should save me about $40/month, we use hot water for pretty much everything. The efficiency is in the toilet from all the calcium and lime buildup. 12 month payback.
I'm always surprised when I see a house with natural gas service, but an electric clothes dryer. That's probably the #3 largest consumer of electricity assuming electric house heating and electric water heating. Even crazier when the washroom is already plumbed with gas service.
I expect everything will be electric one day, but that day still seems very far off. I also expect just 1 data line to the home one day that serves phone, internet, TV, and anything else utilizing data. |
Gas?
I guess you missed my point that gas or propane are carbon emitters. Electricity tied to grid tie solar is not for the most part except when you aren't generating and even then your excess power generation that you sell creates an offset because others get to use it.
Energy is energy and heating water takes a fixed amount of it all other things being equal. Unfortunately electrical resistance water heating is not a great idea because heating water takes a lot of energy and it could use up a great deal of PV capacity unless you are using excess capacity for that purpose explicitly. This is what is making the heat pump water heating process so lucrative from my point of view. Using 3.5 times less electrical energy to heat the same amount of water with the saved power being used to charge an efficient EV seems like a win win to me unless I am missing something. |
In a few years we. The heat pump breaker you will be on resistance heating.
Just remember during this time china likely opened a new coal fired power plant. Going out of your way to save a little CO2 is really pointless now. |
It is pointless to think like this. I believe it is called a self fulfilling prophecy. Saying it is pointless to conserve energy and money is just, well crazy.
Nothing wrong with conserving energy.
With panel prices so cheap and utilities charging so much in some areas you should put up some panels. Unless the power company has stacked the deck so far against you to where you would paying them to produce electricity. |
If you've got solar production and can use it to heat you water, that would be perfect. Probably the cheapest fuel possible since the panels are already purchased and work nearly indefinitely. I saw a video recently of a guy who built a thermal battery for his water heating. I'll try and find it to link.
I've been thinking about HPWH for years, Heat Tap I think was an early add on style. Problem is, during heating season, it takes the heat out of the air in the room to put it into the water. So my furnace has to make up the difference so I'm really still heating water with propane (some heat does come from basement walls/floor).
My water heater also does double duty heating some floor slab mostly at night so I'd just be moving heat, cooling the basement while heating a floor. During summer it would work great cools and dehumidifies the basement while heating water, way better than running a dehumidifier, just too expensive for seasonal use. |
