EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   new 96accent 1.5 5spd. 42.7 (https://ecomodder.com/forum/showthread.php/new-96accent-1-5-5spd-42-7-a-29666.html)
x3user 08-06-2014 10:00 PM
Just bought my accent Monday and today was my first fill... after 385 miles I produced 42.7 mpg, I'm happy with that... but I know I have to remove the little mudflap things get a new non bent door reduce drag on front air dam and ideas about rear tire body covers are in effect... goal is 50
digital rules 08-07-2014 06:45 AM
Congrats on the new car & welcome :) Great job on the first tank & aiming for 50 is a great goal for the Accent :thumbup: Are you using a Scangauge or Ultragauge?
Check out these tips as they are a great tool for improving MPG's. Also set up a page in the garage so you can track your progress.
x3user 08-07-2014 08:33 PM
I don't have a that type of scanner... but I have a WiFi obd2 scanner and it measures airflow through the maf, to track mpgs it is very accurate.
