New Aerodynamic Truck Bed Cover.
1 Attachment(s)
Just learned of this one. Nice styling job. Be interesting to put this one in a wind tunnel. Bondo
https://www.mivehiclesolutions.com/a...conversion-kit https://ecomodder.com/forum/attachme...1&d=1532200453 |
I like that, kind 1970's looking with the louvers.
fROM THE ORIGINAL OPENING LINK: https://static1.squarespace.com/stat...g?format=2500w Not to detract from the tread, but could some of the manufactures be doing small things to help the aero on their trucks? As found on AUTOWEEK Spied: 2019 Ford Ranger Wildtrak roams with Ranger Raptor http://autoweek.com/article/spy-phot...-ranger-raptor http://forums.pelicanparts.com/uploa...1530923643.jpg http://hanabi.autoweek.com/sites/def...?itok=M3_9hzh2 http://hanabi.autoweek.com/sites/def...?itok=wCYO-Bft |
Good find, Bondo.
I'll check it out. |
Someone in the Pelican Parts forum where I posted it just compared it to the Pontiac Aztec.............................ruined it for me.
I still like it, just was an unexpected comparison. Post #41159 http://forums.pelicanparts.com/off-t...ures-2058.html |
I like their solution for rear visibility; using the louvers in place of glazing. So, it is (probably) not water tight, but it is less costly.
Edit: I see it has a glass window under the louvers - which seems clunky, now. https://static1.squarespace.com/stat...g?format=1500w |
No claimed mpg savings figures?
cover
If they did a product placement in a Transformers,Mission Impossible,X-Men, James Bond,etc. motion picture;they'd probably fly off the shelves.:p
The angle is too steep, would not fit the Aero-Template.
That said, I bet it's an improvement verses nothing at all. |
If the louvers were v-shaped instead of straight then they may act like a step hull of a boat, reducing wetted area intern drag.
Making channels for the higher pressure on the sides to merge with the lower pressure center while minimizing disturbance of the front to back flow. Im curious if the severe reduction in Reynolds number would mute any effect from this design in the air, or if the speed at which it works is too high for Road use. Quote:
