New air dam
The factory chin spoiler on my truck had broken into several pieces years ago, and the duct tape holding it together had been replaced several times, so I decided it was time to make a proper air dam.
http://ecomodder.com/forum/member-jr...9-pc120311.jpg I wanted something slightly lower than the factory chin spoiler, plus it had to be sturdy enough to smash into a snowbank or plow pile without damage. So I bought some conveyor belting, stainless carriage bolts, silicon bronze nuts and washers, and built an air dam. The bottom row of bolts fasten to angles that bolt to a second piece of conveyor belt intended to add stiffness to the visible piece. I have not yet observed whether the air dam flexes back under wind loads on the highway. Unfortunately, I cannot properly test it. Any MPG difference from the factory setup will be small, and my driving habits will change since I retired last week. |
Looks good. Any plans to eliminate that antenna?
I support the decision to upgrade, but for the stock pieces after duct tape the next step is:
http://ecomodder.com/forum/member-fr...hlf3lbyhtg.jpg Else Zip ties. |
Looks good! I like that it is out at the leading edge of the vehicle. Even if you don't notice the MPG as much, I bet you will notice the better handling that would provide to direct more air over and around than the factory setup.
Below is my solution, obscured in the photo is the cross bar forming the big "U" shape for the metal. The lower lip is braced only for about 18" in the middle, but works because of the curved shape. Chin Spolier - fast/easy/cheap/effective - Page 2 - Pelican Parts Technical BBS http://i184.photobucket.com/albums/x...psdd244397.jpg Quote:
Congrats on the retirement! And the chin spoiler.
A photo showing the air dam stiffener from underneath. The angles are UHMW plastic from McMaster-Carr ($3.00 per foot).
http://ecomodder.com/forum/member-jr...3-pc160310.jpg It does a good job of holding the air dam to the same curvature as the bumper out at the ends, but I suspect the middle blows back. I'll be adding a couple of braces similar to what Kach22 did, except my stiffeners will by something 1/8 X 1 steel so that I can bend them back easily after contacting a snow band. |
Snow collected inside the grille block when driving through falling snow. My guess is that a lot of air is coming up from underneath the new air dam. If so, there's more air going through the radiator than needed. If so, that excess air is AIR DRAG.
http://ecomodder.com/forum/member-jr...0-153658-1.jpg Thoughts or suggestions, anybody? |
Turbulence
Looking at this picture reminds me of those wind tunnel tests of a box trailer and the air just swirls at the back, it may be doing so here in a similar fashion. |
This plate splitter or plane would not only split air at the leading edge but provide a clean edge from which the air could release from. https://robrobinette.com/S2000Aerodynamics.htm https://robrobinette.com/images/S200...r_Pressure.jpg Quote:
http://rebelautoworxs.ca/Pictures/Splitter.jpg Quote:
EDIT: I sketched up what I think is happening. Aerodynamics by George Kachadoorian | Photobucket http://i184.photobucket.com/albums/x...psj6oswyeh.jpg I would not make it like my splitter, which was an outer lip only - you need a to establish a parallel plane to the ground because your stepped up backer is a step up, and is drawing the air up to fill the vacuum. Chin Spolier - fast/easy/cheap/effective - Page 2 - Pelican Parts Technical BBS http://i184.photobucket.com/albums/x...20Up/CHIN7.jpg I have no internal step up on mine shown above, which is maybe why I got away with my design. Yours needs to be different because yours is different. In other words: You built an upside down Gurney flap! (without the splitter/rear deck trunk/wing part) The chin spoiler is the Gurney flap, second flap is the internal bracing. http://blog.octanenation.com/kubica-...-thanksgiving/ http://i1.wp.com/scarbsf1.com/HANDFO...size=610%2C413 |
And now for some results.
Since I installed the air dam, nobody has had anything to say about the air dam, while several people commented on the topper. I take this to mean that the air dam looks close enough to "normal" that nobody notices it enough to mention. I now have MPG results from December 2016 thru February 2017, the three months that I use to calculate winter gas mileage. My mileage for Winter 2016-17 was 33.0 MPG, while the best previous winter was 2015-16, where I got 31.75 MPG. I no longer drive three miles each way to work, so that should improve mileage by 0.7 to 1.0 MPG. The improvement attributable to the air dam is thus 0.25 to 0.55 MPG. It will be interesting to see what I get for mileage next summer, because I averaged 38.6 MPG last summer. I really want to get to 40 MPG. |
I had had hopes for wheel covers, so I tried them Summer 2015. I did not get a measurable change in fuel economy. The discussion is posted here: http://ecomodder.com/forum/showthrea...yon-32761.html and results are summarized on the last page here: http://ecomodder.com/forum/showthrea...yon-17070.html.
