new car
1 Attachment(s)
so after getting a new job farther from home i realized the f150 was gonna cost to much to drive every day to and from work. so i began searching cl for a small car and found a geo tracker for 850. so i went to look at it and ended up talking the kid dow to 500. right now it needs a little work but atleast its drivable and so far seems good on gas ill have actual mpg numbers friday when i refuel it.
not exactly an eco car, but probably a lot better than you're F150! :thumbup:
I imagine the gas needle moves just a little slower!!!!
Any more details? Is it a 5 speed or auto? 4WD or 2? Year? 16 valve engine or 8 valve?
It's good to see another tracker on the site :D Here is mine [IMG]http://i108.photobucket.com/albums/n...ps30ece493.jpg[/IMG] |
razor02097 its a 95 1.6 16 valve 4wd 3 speed auto it has 140k on it right now its got a ghetto 4 inch lift in the rear and a 1 inch spacers in the front with 30 inch tires im pulling all that out to replace it with a combination of lift parts to suit my needs throwing 31s on it and calling it good suspension wise. the power steering pump went bad on the previouse owner so he just pulled the pump and left every thing else so im gonna get a manual steering box for it this weekend
Cool deal
If you have any desire... here is my project thread... Project: Tetanus (warning: picture heavy thread) - Suzuki Forums: Suzuki Forum Site |
22/24 mpg for a '92 2WD. Not bad. You could probably hit 30 hwy with some aeromods.
I already have a thread started with ideas for an aero hatch...
http://ecomodder.com/forum/showthrea...tch-24651.html Here is my grill block made from aluminum... Not a big improvement but the coolant temp stays steady on the freeway now. http://i108.photobucket.com/albums/n...-32-30_655.jpg |
An uncle of mine had a 4-door one (Suzuki Vitara) with the 5-speed manual. With a Volkswagen 1.6IDI Diesel swap it got 42MPG all-around without any other mod.
