New car fashion or function
So I'm walking out of work and there's a brand new 2011 Prius sitting right next to a brand new 2011 BMW X3. Now there's not a heck of a lot these two cars have in common, but there was something remarkably obvious; the upward sweeping body fold leading from the front wheels to the upper end of the tail light.
http://priushybridcars.com/wp-conten...20356693-E.jpg http://www.carsview.net/up/images/2011-bmw-x3.jpg Now that I look around, this trend is everywhere, so is it fashion or function? It appears like it might divert air from low on the car into the area where the most 'suction' would be in the slipstream of the car. http://media.il.edmunds-media.com/hy...429102_717.jpg 2011 Elantra http://www.blogcdn.com/www.autoblog....80-003_opt.jpg 2011 Fiesta |
im pretty sure its functional within a fashionable sense ;)
My 1966 Mustang had something similar, I think it's for attracting door dings from dingbats.
How To Replace Your Mustang Door's Outer Sheetmetal | Mustang & Fords Magazine Article at Automotive.com http://image.automotive.com/f/howto/...mage_large.jpg |
It would make sense that it would be at least somewhat functional. Most of us know, and if you don't your about to, that the wheel wells are an area where air is slowed down because of drag which makes that area a high-pressure area of the car. If you ever drive behind someone in the rain you can see the effects of this b/c there it a ton of mist and rain flying out of the wheel wells. So these body lines could be trying to suck that air out a little more and guide it to the place it is needed most - where the rear of the car creates a vacuum. If they can feed more air softly around the rear of the car, they can fill in part of that vacuum that is basically sucking the car back. Then again, the body line has been around for a while so it could just be a trend.
A very fashionable & trendy character line that parallels or tapers along with the beltline. It gives definition & personality. Depending on the design language, it could be casual, formal, slashing, or geometric. Sometimes too many lines could make it too fussy.
endurance -
Thanks for posting. I love this stuff. What I look for is whether it is "inline" with the door handles. Aesthetically that is what I prefer. Here is one I have noticed. I call it the "J-Line" or "The Hook" : http://ecomodder.com/forum/member-cf...olet-cruze.jpg (It also meets a corner of the rear tail light) Now, you could argue that all cars have this detail nascent in their design because most cars have circular front wheel wells that "trigger" the design lines in some way or another. My distinction is how "crisp" the geometry of the J-Line actually is, aka how easy is it to see. In the case of the Chevy Cruze, the front headlights are partially shaped by the J-Line, and it continues without interruption to the end of the car, so it is very crisp. CarloSW2 |
A crease like that is going to make the door skin stiffer as well, allowing for thinner door skin to be used.
Having hung out with industrial design students and instructors it would appear to me that they like the aesthetic of lines like that and it is what is being taught in school. |
Hmmm...maybe one too many.
http://wot.motortrend.com/files/2011...ee-quarter.jpg And an understated example. http://www.classicargarage.nl/common...6_exterior.JPG |
I've spent countless hours trying to sketch a car that is pretty aero and good looking. I wrestle with ways to get away from that aesthetic treatment, or minimize its negative aero effects. |
1 Attachment(s)
Here is one which is an earlier example, maybe ahead of it's time by a few years.
Toyota Celica Automotive info » Blog Archive » Toyota Celica http://automodelsinfo.com/wp-content...-celica-10.jpg On the soft side, the jellybean car has yet another adaptation of it. 1997 Ford Taurus |
I vote cosmetical, function maybe to help stiffen the panel, but aero wise, I can't see it doing much if anything.
The character lines look like they hurt aero. I think they do add stiffness which might help a little in a side impact.
There may be some aero function, on some of the cars, at least. The wedge in front of the front wheel may serve to kick the air flow out and around the churning wheel? And the trailing crisp edge on the Prius behind the rear wheel forms a Kamm back of sorts. The Prius also has a vestigial rear wheel strake.
I think the hard chine along the fenders and doors is a bit of styling, that has virtually no aero "cost". |
kach22i -
I think you're right the Celica. I disliked it at first as garish, but over time I grew to like it as the field "caught up". CarloSW2 |
I vote for functional, by default. Can't be for style, 'cause it's ugly. Makes the car look even fatter in the rear than it actually is. Or maybe they're trying to appeal to the... oh, call it the chubby market to be kind. "Oh, look! That car has a fat butt, just like me!"
Well, I suspect it's a bit of both. Unlike the two examples kach22i put up, these 2010s and 2011s have a noticibly rising line to the crease, not just following parallel to the ground. I'd suspect they're trying to move air into the low pressure zone behind the rear window. The only 2010 I saw with this was the Prius, but now it's appearing everywhere including the new CR-Z (just saw my first one in the parking lot at work today).
I tried to look at highway MPG changes, but while every car I've noted got better MPG with the introduction of the upward wedge, they also all had changes in engines that probably played as big or a bigger role. The Prius, which doesn't appear to have had a change in displacement, had other changes which resulted in an increase in highway and city mpg by 3mpg. |
My opinion is that it adds stiffness to the panels, and is also a styling exercise. I do not think it serves any aerodynamic purpose.
I looked at lots of cars on my way home today, and not all have these "lines", and the Seat has them going downwards! |
crease
I vote 'structural',with creative license.
Daimler called it 'Zeppelinesque' I think. The corrugation allows for stiffness in a thin,light,fuel-saving panel which would otherwise 'tin-can' or resonate. The car skin can wad up in a collision absorbing kinetic energy of impact,leaving the safety cage and airbags as the 'barrier' to protect the occupants. Any kind of crease adds the stiffness,so designers have a large degree of creative latitude in its use. As to aero,I'll await an SAE Paper or journalistic synopsis of such a paper. |
There may be some minor benefit from stopping water spray and road grime from getting onto the side windows as well.
Not sure about the aero benefits. Possibly there to direct air to the upper portion of the rear panel? Just afew thoughts, Peter. |
Beautiful though!
silverinsight2 -
My Dad's Impala, Yay! CarloSW2 |
And then maybe remove some of the excess from the front, and the body overhang outside of the wheels... Guess I was an ecomodder at heart, even back then. |
To each his own! I am a car guy first, and EcoModder second. What ever I drive I'd like to make it the most efficient I can, but not necessarily chop, cut, graft, and modify until it matches "The Template". What a boring life if we all drove around in templates. If this was my car, and I wished to Mod it, I think a 6.5 turbo diesel with some tall gears, would be easily capable of 25 mpg with very good performance. Someone should wind tunnel one of these just for the heck of it.
The wind tunnel testing ( with images ) was done to prove whether or not the horizontal areas of the cars tail provided any lift at speed. I think Aerohead posted the article. |
That car would make a great solar oven!
It's got PV cells in part of the roof ;) |
Very good, Thanks!
euromodder -
http://www.carstyling.ru/resources/c...concept_07.jpg And here it is with aerohead's template : http://ecomodder.com/forum/member-cf...o-template.jpg CarloSW2 |
splash and spray
I found a Mercedes Benz ad from around 1981.In the ad illustration a number of the cars features are explained.
One was a rubber flow fence adhered to the body sides which was said to prevent splash and spray from fouling the side glass of the car. |
