New Commuter Bike
Brother was cleaning out his shed and came across an old GT Outpost circa 1998. This would make a much better commuter then my current Road Bike so I went ahead and took it.
Here's the before. http://i160.photobucket.com/albums/t...oto/E-Bike.jpg So for the last 2 days I've been working on it replacing parts from my bike parts that I've accumulated over the years. Things done: New cables 700cc rims instead of 26" with 28C tires Reworked the brakes to accommodate the taller tires. 7 speed rear 11-19 cassett New chain New Seat Swapped over the e-bike hub kit. Clipless pedals Newer rear derailer This will make a much more comfortable ride and is stiffer then the road bike so low speed control is much better then before and the ride is much smoother with the wider tires. It also has eyelets so I can put fenders and more racks if needed. I took it on a 13 mile trip today and it felt good. I've removed the front derailer and an just running it as a 42 tooth machine. Finished product: Just need to add fenders.:turtle: http://i160.photobucket.com/albums/t...loto/Ebike.jpg |
Better commuter than a road bike!? I'm shocked.
:) Nice ride! |
1 Attachment(s)
Hey! That's my mountain bike frame! :) Mine's a '97 Karakoram.
Is that one as small as it looks?? http://forum.ecomodder.com/attachmen...1&d=1210551422 |
Looks good. I was wondering about the wheels. So, you fit road bike wheels on a mountain bike? Did you run into any problems with the brakes?
I did know that it was possible to do that. |
Yes better commuter. My road bike is set up to go fast. The Hybrid you sit a littler taller for better visiblity in traffic and for me an upright postion is more maneuverable in traffic. If has flat bars and you can add racks, lights, fenders and run wider tires(less flats and more comfortable ride on crappy roads). :) In my experience the difference in speed between a MTB and a road bike is about 2 mph with slicks on a 26 inch rim for a normal commute. So on a 20 mile ride you're looking at 6-10 minutes. I don't know how much of a hit if any on 700cc wheels it will take. That's what I mean by more comfortable commute. Quote:
Nice!
So you can fit wider tires then? What size tires are you running now? |
