New to EOC.
I've just recently started working on EOC. It's already given me a huge jump from 28-9 mpg tanks to 31-2 mpg tanks. Where hypermiling has made the near mythical LGT 400 mile tank a given, hypermiling with EOC has put me in a good position to get regular 500 mile tanks.
So I'm a little over halfway through my fourth tank using EOC and I'm noticing new things and running through beginner learning experiences. To date: -I've got to work out that kill switch. It would make shutting off a whole lot smoother, I wouldn't lose "credit" for the distance traveled while the key is off and I wouldn't have to wait for Torque to get back in touch with the ECU. I hate being without that load gauge. -Torque maxes out at 255 mpg for its instant readout. -In my car, bump starting in fifth gear above 10 mph is no problem. -Bump starting in first gear is bad. -Not having power brakes is horrible if you: 1) aren't paying attention to the world around you 2) don't know how to drive 3) panic The third time I hit my brakes in a glide this morning, nothing happened, but with a quick bump start the problem was over. Now I need to familiarize myself with non-power brakes. -Driving along without the engine running is one of the most thoroughly amusing things I've ever done. So, what other litle tidbits am I going to come across in the near future? |
For me it is about trying new stratagies and reprogramming myself to use the techniques here to their best advantage. I do know that once I started dropping my coast-to speed and using a lower gear(say 3rd instead of 5th for 40-25 mph P&G) my mileage bumped up a good bit. Also, if there is no traffic behind you, it's AMAZING how far you go at 25mph. I'm still learning as well and what I've come up with is; know your car, know your route, and know yourself. If your car likes accelerating at 70% load more than 80%, use it. Find your routes best oppertunities for differant techniques. No two corners/hills/flats are exactly the same. And last, know how good/bad of a driver you are and what you can get out of your machine. Kill switches are wonderful, and I agree, coasting is the closest thing you can get to being a kid again:eek::D.
YMMV |
Slower is better for mpg. I used to P&G in 4th gear from 25-40 mph. 8 seconds pulse, 24 second glide, 55-60 mpg. Dropped it to 3rd gear from 20-30 mph, and the P:G ratio is about 7 seconds pulse, 40 seconds glide, 60-70 mpg. Just for kicks, I tried 10 miles of 2nd gear P&G (10-20 mph). That's about 3 seconds pulse, 30 seconds glide, and 94.5 mpg! 5th gear highway P&G from 50-60 mph is about 9 seconds pulse, 16 seconds glide, and 45-50 mpg. YMMV with a different engine, tranny, car, etc., but the idea's the same. Your pulse:glide ratio determines your mpg. The more you glide in relation to running the engine, the better your mpg.
Bump-starting in a corner is interesting if you have power steering. When the power steering pump starts back up, the steering wheel force required to hold a turn decreases, which you have to anticipate or deal with.
I dealt with it by pulling the PS pump and draining the rack :) |
