the new ford fiesta --- Is This Tranny What Ecomodders Want?
So i don't know if a lot of you know, but the new ford fiesta gets better gas mileage with the new doulbe clutch automatic transmission than what it gets with the regular manual (stick shift)
... Question is though... Is this the ultimate transmission for Eco modders? Or can we attain better mileage from someone who drives manual transmissions the proper and fuel efficient way? |
With pulse and glide you'll be able to beat the auto trans. Cruise control / constant speed I imagine you'll still beat it in town. Cruise control / constant speed on the highway I bet the auto wins.
As long as the torque cinverter is gone, its a step in the right direction as long as both clutches can be disengaged at will.
I think it's what we as ecomodders want all automatic transmissions to go to, for the general public. (I want my wife to get one)
I was intrigued when they released that tranny. If it stands the test of time and doesn't self-destruct, I think it'll be a very popular style. |
Can I P&G the auto?
Don't see why not, just leave it running and throw it in neutral. I found that I actually get better overall fe doing that with my Jeep. P to 50ish, G in neutral down to 33, but I don't shut off the motor, cause it's an auto tranny.
Do you think maybe it will be even easier to p&g with it? Wouldn't it be "smoother" unlike the jerky transmissions of today?
Since it has two clutches one would already be engaged so it would just roll onto gear once your glide is done? |
It's not bump-startable. It does NOT have torque converter. In the Fiesta, you don't get "manumatic" control, though. It's got D, but no +/-, no paddle shifters, etc for you to force a shift.
I think the design is good, and we should WANT auto trannys to go this route; but if you love EOC'ing and bump-starting, you're out of luck. |
Im sure theres a way to do some modding to get control over the trans.
Likely, but it's probably not good for the tranny. I know you can kill the ignition in my jeep in any gear but overdrive and if you turn the ignition back on while still rolling, it will "bump start" the engine, but I don't think it's good for the system. Auto's just aren't made for that abuse... I know apples to cumquats comparing a slushbox-tq to a double-clutch... but that's my two cents :D
These new dual clutch auto improve on the automatic trans by removing a lot of the power losses through no torque converter and some even no oil pump . You can let it auto or manual shift it, at least this articles seems to imply that.
Ford also implementing start/stop tech, were engine shuts down at stops, like waiting for red light . DailyTech - Ford Powershift Gearbox Coming in 2010, Brings Clutchless Shifting |
JeepNmpg2 - That's because if you kill the ignition without taking the tranny out of gear, you're just forcing DFCO. The engine is still spinning, as is the tranny pump. The tranny doesn't know or care that the engine isn't still running. When you turn the ignition back on, the fuel and spark comes back, and the engine continues running normally.
Maybe weight and rotating mass? If dropping 30 pounds (cited in article) equated to 9% increase in FE in other cars, everyone would keep their cars as empty as ecomodders/drag racers. Either way, very exciting transmission option. I could even handle it, and I'm excited to hear how they do the shut down when idling option - how long will it delay from when you release the brake pedal to when your car starts going?... |
Probably .9 percent.
Released by a math-challenged publicity specilist is my guess. |
Even the BMW Z4 has better FE with its DCT - around 5% in the Euro-cycle. |
I'm not terribly excited about the dual clutch setupm but it's way better than a regular automatic, and should be able to bump start with a bit of logic though (it should be fine to bumpstart it given it IS a glorified manual) so I wouldn't be too put out if my next car had one.
I think overall it is a good thing. You would have redundant clutches if something happens to one, if it is slipping, just drive home using 2nd, 4th, and 6th (or 1st, 3rd, 5th). You should get more reliability than a regular manual trans, once it's all sorted, but it will be a few pounds heavier and likely still have more losses then a well managed stick shift. edit: found a picture: http://www.niot.net/blog-images/27_M...ox-for-201.jpg |
I wonder how much more it would be to replace the clutch on those transmissions??
Then again.. They might last longer since you use each one half of what you would normally use them... |
Is the automatic flat-towable? If not then the manual is more hypermiler friendly, if you know what I mean. ;)
It *should* be flat towable, as it's just a specialized manual tranny.
