New front air dam
I thought it was time that I stopped just reading about mods and tried experimenting with one so I built a front air dam last weekend. I'm quite happy with the look (the less important part) but I'm not sure yet if it is going to help MPG. I already mounted a partial front pan last year and redid my grillblocks in the fall. Lowest suspension parts are at 6" and bottom of dam is 5.5". Eventually I would like to do a full pan and widen the front bumper to clear the tires but that is not an outside project at -20c. Anyway, I had a 200mile highway run yesterday that I make occasionally and mileage was only 8L/100km avg. at 65-70mph but -20c to -12c temp may have had some effect. I avg around 7.6-7.8 in the summer if the winds not blowing hard. I need to do some sort of A B A test when it warms up to be sure I guess. It may be too low or maybe I should have left the middle open. It may be creating more turbulance at the front tires since it doesn't clear them even though I tried to deflect it out at the end. I would appreciate your feedback. I was going to post pictures but apparently the file sizes are too big.:(
puddleglum -
The album feature will upload any size JPEG. Go as follows : User CP -> Pictures & Albums -> Add Album Create an album and add a picture to it. The album will automatically downsize the image to fit. Then click on the picture and you will have a "BB Code" text of the image that you can copy into your post. CarloSW2 |
i'm so confused. you talk mpg, mph, & 200 miles. but you posted 8L/100km.
so i did some research. you got 29.40 mpg according to this site: http://www.pege.org/fuel/convert.htm |
Carlo, thank you for the help, I'll try this again. Luvit, sorry about being confusing. I was trying to use US terminology, but I do everything in metric and I didn't take the time to work out the conversion.
Here is my second gen. grill block with adjustable lower baffle and the pan before adding the air dam. http://ecomodder.com/forum/member-pu...re1521-004.jpg http://ecomodder.com/forum/member-pu...re1526-005.jpg This is the filler pieces I built to tie into the small factory air dam and a piece of vinyl siding starter strip and some rubber cove molding that made the air dam. http://ecomodder.com/forum/member-pu...re1520-003.jpg Here is some assembly and the finished product. http://ecomodder.com/forum/member-pu...re1523-007.jpg http://ecomodder.com/forum/member-pu...re1524-008.jpg http://ecomodder.com/forum/member-pu...re1522-010.jpg http://ecomodder.com/forum/member-pu...re1525-009.jpg Sorry that some of the pictures are dark but please tell me what you think. I |
grill blocks look great!
by the way, how cold has it been for you this week? |
lows have been around -5 to -15F with windchills -15 to -25F. Highs around 0 to 10F. Not as bad as a few weeks ago, hit -40. It's supposed to warm up this weekend though.
puddleglum -
Excellent execution! I like your choices of materials. We usually see garden edging for this kind of stuff. I see you have a block heater "ceegar" (plug), so to speak, ha ha. ... Or maybe a battery trickle charger plug?!?!? CarloSW2 |
That is one of the cleanest set of mods I've seen. Looks totally stock!
BTW, What kinda vehicle is that? I can't place it. |
Clean looking work.
It'd be great if you make a garage entry for the car. Then we'd all be able to figure out what it is. :) |
Love the grille block. It almost looks like a factory option!
