EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   new guy (https://ecomodder.com/forum/showthread.php/new-guy-7761.html)
thebluelightbulb 04-06-2009 03:12 PM
new guy
hi! im new! first, here's what i drive:
2006 Pontiac Wave 5dr (...aka aveo...). fuel consumption is within factory specs of 6L/100km highway and 8L/100km city. i employ simple tecniques so far, such as green-light timing, rabbit timing, slow accel and brake, commuting in an 80km/h zone as opposed to 100km/h zone.
...thebluelightbulb...
MetroMPG 04-06-2009 03:30 PM
Welcome to the site. Have you got fuel consumption instrumentation yet?
What part of the province are you in, if you don't mind me asking?
cfg83 04-06-2009 04:16 PM
1 Attachment(s)
thebluelightbulb -
Welcome to EM! Do you know what your tranny gear ratios are? I am curious to know if you have a better "eco-tranny" than what you can get in the USA.
I'm a blue-dot fan myself :
Wirth's Custom Automotive: 1956 Chevrolet Tail Light Lense w/glass blue dot
Attachment 3173
CarloSW2
Daox 04-06-2009 05:11 PM
Welcome to the site. How are you liking the car?
SVOboy 04-06-2009 05:37 PM
Welcome to ecomodder! Be sure to fill out a fuel log for your car, :)
theunchosen 04-06-2009 08:21 PM
lol Are you moderators required to stop in here every ten seconds?
Whatsup TBLB?
In the event you run into someone who is grumpy here. . .they had a low MPG tank. . .it happens to us all.
Not very often though! ^_^
Depending on what you use your car for and local temps deletes are usually the easiest thing to udnertake. For example, you live in Canada and I am not sure how hot it gets during the summer. Cracking or opening windows all the way is more FE friendly than AC. Mine broke so I ripped it out. . .I mean um, I did it to conserve FE ^_^.
thebluelightbulb 04-07-2009 08:46 AM
i don't have instrumentation yet. im wondering if i should get a scanguage or see if i can cheap out with a vacuum gauge.
im in brantford. i commute to hamilton 5 days a week. one-way" 48km.
thebluelightbulb 04-07-2009 08:48 AM
[QUOTE=cfg83;96115]thebluelightbulb -
all i know is that i have an aisin automatic. i have to look up my gear ratios. im sure it's the same as the us version.
RobertSmalls 04-07-2009 09:49 AM
No, get a ScanGauge. It'll be the best $150 you'll ever spend. It gives you a much more complete picture of what's going on under the hood, which is important if you decide to do something like a grille block (which you should do this winter). Welcome to the forum!
MetroMPG 04-07-2009 10:38 AM
An alternative to the ScanGauge, if you only want fuel consumption info (or can't afford the SG), is the MPGuino. Requires a small amount of skill to install & calibrate.
MetroMPG 04-07-2009 10:39 AM
theunchosen - ha! It did have the impression of a sort of swarming, didn't it? :D I'd be suspicious, personally.
cfg83 04-07-2009 10:43 AM
MetroMPG -
For a long time now I have thought of myself as a Church greeter. The Church of MPG, that is, :p .
CarloSW2
thebluelightbulb 04-07-2009 03:16 PM
i'll look that up and see how much that costs. i can't exactly splurge on a scanguage right at this time.
thebluelightbulb 04-07-2009 04:09 PM
i bought it brand-new 3 years ago and i enjoy driving it. it corners well and accelerates well enough for my purposes.
