Old 05-12-2008, 10:29 AM   #1 (permalink)
Big El Cheapo
big swede - '01 SAAB 9-5 2.3lt
90 day: 31.96 mpg (US)
mighty mite - '09 Honda Fit Sport
The V - '02 Honda CR-V EX-4WD
Ody - '09 Honda Odyssey EX-L
Hello from a hypercommuter
Well, kinda. I have a 50 mile one way commute to work. I drive a 2001 SAAB 9-5 2.3l 4 cyl turbo. Have to use premium.... Stock hwy mpg is 27. I tend to get up in the 30's, though, as many 9-5 drivers do. Just looking around for fuel saving tips.
Old 05-12-2008, 10:40 AM   #2 (permalink)
Hello and welcome to the site bkrell. The first area to focus on is driving technique. You'll see your best and cheapest gains here. Check out our list of driving tips here:
http://ecomodder.com/forum/EM-hyperm...ecodriving.php
Pick out a few and watch them increase your FE, then try a few more.
Other than the driving tips I'd look into aero mods as your traveling at high speeds. Check out the aerodynamics forum and its sticky.
Old 05-12-2008, 10:47 AM   #3 (permalink)
Big El Cheapo
Yep I've read the tips and I had really thought about aero mods. I'll certainly need to take a look at that forum. I've got to research a few of the issues reagrding my aerodynamics....
Old 05-12-2008, 11:11 AM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Is premium strictly required? Will the ECU not back off timing etc., based on knock sensor feedback if you run lower octane gas?
Welcome to the site.
Old 05-12-2008, 11:17 AM   #5 (permalink)
Big El Cheapo
No, it's not strictly required but recommended. But I've always observed a drop off in mpg due to the timing being backed off. Now, I've never tried running the car on 87 being overly fuel conscious. Perhaps that's worth an experimental tank or two.
Old 05-12-2008, 11:18 AM   #6 (permalink)
Big El Cheapo
Wow, that banner makes me look like I'm actually driving great already......
Old 05-12-2008, 03:16 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
bkrell -
Welcome to EM! From what I have read, the key to Turbo's and MPG is driving below the "turbo activation line". You've got the small displacment, so you should be able to get wring some nice MPG out of your Saab.
Are you a B235E or a B235R? I am thinking B235E because of your garage baseline comparison MPG. I don't know what the B235E engine(?) designation means, I just read it on the EPA mpg website.
CarloSW2
American Solar Energy Society
Old 05-12-2008, 03:16 PM   #8 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Get a new Gen ScanGauge II.
It has read out in cost per mile / trip/ tank/ day etc. I tried it on the Vibe and found out that Premium cost about 1/3 cent per mile LESS than 87 (at current price levels). May/ May nt be worth while loss in MPG switching to lower octane .. .
Welcome to the site. I think you might be the first Saab here.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-12-2008, 03:19 PM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to ecomodder! Definitely check out the ecodriving tips that Daox linked earlier,
Old 05-12-2008, 03:42 PM   #10 (permalink)
Big El Cheapo
Originally Posted by cfg83 View Post
bkrell -
Welcome to EM! From what I have read, the key to Turbo's and MPG is driving below the "turbo activation line". You've got the small displacement, so you should be able to get wring some nice MPG out of your Saab.
CarloSW2
B is the SAAB engine family.
23 is 2.3 liters
5 I believe means it's the fifth iteneration of the engine
the R engine must be the higher output Aero model (and all 9-5s now) that make 250-260 hp depending on year.
The figures I inputted in the "garage" are the revised EPA numbers. But oddly they state that the higher output engine is the only one requiring premium. I know in my manual it's recommended, not required, but I've never used 87 were it didn't sound like I had a tdi under my hood.....And I'm pretty religious about fuel system and combustion chamber cleaning. I regularly take a peak down into my spark plug holes to check for carbon.
Here's the quote from the owner's manual:
Fuel grade ________________________ Unleaded gasoline
AON 87–93.
For optimum performance Saab recommend
the following fuel grades:
2.3t _____________________________ AON 90
Around here my only options are 87, 89, and 92 or 93. Any time I've run 89 it's been just like using 87. But, as I said, I'll try it running off boost as much as possible and seem if my mpg changes. In prior experiments, I'd get as much as a 4-5 mpg drop.
As for Scangauge, I have a trip mpg function right now along with a "distance to empty function." It was pretty accurate when I'd checked it in the past but perhaps it's time to check it again...
