new guy, got a truck, tools, and too much ambition
liek the titel says, ima NOOB!:D i got myself a 1994 bronco, and ive decided it will take me as far as it can. of course with a v8 its not very efficient, but i set a rather high goal and i could use all the help i can get. right now im on FSB and ive got a full build thread there.right now it has factory maf and sefi, 130 amp 3g alternator, new cap/rotor,coil and motorcraft coppers. plans are in the works for an electric fan, full belly pan/skid plate and a new y pipe and raised exhaust. also have a ported and polished throttle body(not installed) and throttle body coolant bypass. nthe nut behind the wheel is already well adjusted. :thumbup:
so ive got qestions now - can i replace my injectors with different ones that will be more efficient? -it is worth at least 2 mpg to go to a electric smog pump? -is a cold air intake or warm air intake better for FE? -any other mods i can do? long time stalker, now a member:D |
Welcome!
Aerodynamic mods will help along with adjusting the "nut" behind the wheel. |
