a new hypermiler on the loose?
Hello all,
I'm glad to have found a website like ecomodder, while I become more and more interested in getting every mile out of my tank. My name is Cedric - english name - my father is originally from France, my mother from Germany and my wife is from Holland, but I live in Belgium with my family (yes, the land of chocolate, waffles and the smurfs). Does everyone follow? It doesn't get more European than this, sorry! :p I own a green Skoda Fabia Estate since 2011. It's actually a Czech Volkswagen Polo (all of VW technique and materials), but in a roomier stationwagon version and with the new 1.2 CRTDI on board. This one is still my first car and it has been quite practical, reliable and economical so far without any changes. Without modifications and my 'normal' driving (65MPH) it gets an average of around 55 MPG (more in summer, little less in winter). Now, my goal is to achieve improvement with some modifications. I'm eager to learn more on this forum! Bye! |
Welcome to the forums! If you haven't already seen this list, it's a good place to start: https://ecomodder.com/forum/fuel-eco...ifications.php
Feel free to ask for help or clarifications. I spent a long time browsing this forum when I first discovered it, can't tell you how many hours I spent reading! Sounds like you do pretty well with your car as-is. My advice would be to start a fuel log, and get yourself some sort of instrumentation---Scangauge, Ultragauge etc. The fuel log is a neat tool because it shows you how various changes to your vehicle affect your mileage. https://ecomodder.com/forum/fe-graphs/graph6135.gif It also shows you the effects of summer and winter months, as you can see the yearly dip in MPG when the weather turns cold (and here, rainy). Outside of that, switching to synthetic oil is a good and easy mod, if you don't already use it. I waited until I found it on sale at Costco and bought boxes of the stuff, as well as watching sales on oil filters. My cost ended up being only about 10-15% higher than conventional oil, with the added benefits of longer oil change intervals and smoother operation. Good luck to you, and have fun! |
Welcome to the site Cedric. Looking forward to seeing what you can achieve. 55 is already pretty respectable.
@Flakbadger & Daox
Thanks for welcoming me and I appreciate your instant help! :thumbup: I have noted my fueling data for a long time on a german website called spritmonitor.de. The total average from 0 tot 100.000 km (60k miles) was exact 54 MPG. But after a few years without keeping it up with it, I notice that the engine runs smoother and better with age. So it's time to pick up some new data and optimize the car. I saw some awesome things on this beautiful forum like grill blocks and moon discs, those are quick wins = not expensive and easy to install. |
http://i.imgur.com/MaErhHF.jpg |
Welcome Green. It's good to see another diesel on here. I would start with tire pressure, ScanGuage and upper grill blocking. I did mine with black insulation foam for plumbing pushed between the slats. It is easy to remove if needed but I have never felt the need in 15 years.
https://ecomodder.com/forum/showthre...tml#post485092 |
GreenTDI, I started a thread about Eco-driving the TDI diesel that you may find helpful.
https://ecomodder.com/forum/showthre...tml#post621801 FWIW I have not had good luck with smooth wheel covers on the Golf. I have tried them multiple times both A-B-A and over several full tank fills and they do not seem to increase my mpg. They may actually hurt my mpg. Heresy!!! Julian Edgar's book quotes several studies showing why my results may be correct, at least for my car. I need to start a thread if I can ever figure out how to add photos. What transmission do you have in your car? |
@ Cocylist!
Thanks! Love the way a TDI sounds and drives, especially the ones with uneven amount of cilinders. Raw when idling but smooth when driving. My tire pressure is already quite high: 2,8 bar. But the stock tires are too wide and will be replaced next year with narrower ones to reduce rolling resistance. A lightweight rim could help you more than closed hubcaps, perhaps. But they are very expensive. I'm looking for some forged Audi rims, https://www.original-felgen.com/8l0601025ez17.html The gearbox is the well known 5 speed manual - MQ250 - also used in the Golf. But mine has probably a wider ratio, so a longer 4th and 5th gear. |
Hi GreenTDI. Is it a Greenline version you are using? I live in Switzerland and own a Octavia 3 Greenline Combi. Because of winter and shorts trips to ski resorts (I have only bought the car in November), my mpg has been only 4.9l/100km (48mpg us). But with hotter days, longer trips and now summer tyres I am hoping to get much better mpg (obd value on current tank is 4.0/100km or 59mpg). I would be happy to discuss how to get the best of our cars :)
@ ptitviet
Hello! It's not a greenline version, but a 'normal' car with the 1.2 TDI. That means additional weight and no start/stop or a lower chassis. I have to say that all of those things don't make a big difference in consumption, it's mainly the way of driving. But every bit helps! You have already a good mileage, the Octavia is a bigger car and short and cold trips doesn't help. I love Switzerland, it's beautiful. But cold in winter and quite hilly! So try to maintain 100 km/u on flat road, overtake and accelerate during descents and slow down slightly on hill climbs. Increase the tire pressure and get a winter grill cover. That's also my first plan :) |
I think I have found my first improvement. It's a front radiator/grill cover. There are some stock covers for my car on the market, mostly for VAG cars (VW Skoda Audi Seat) Thanks Google!
It covers up the biggest opening and I wonder if it will reduce drag and will warm up the engine faster. http://www.superskoda.com/images/Plasty/f2f-fbgcvr.jpg @ ptitviet: there are also grill covers for Octavia models: Octavia III - winter grille cover in great OEM design - KI-R : superskoda.com |
Oh GreenTDI just awesome! I didn't know these covers existed!!! I will buy one, though there is only for the upper grill and not for the lower on Octavias. By the way with this cover, you have just bought yourself a "budget" greenline fabia :)
@ ptitviet: the company who make this covers for the Fabia (team HEKO) has some more products on their website. These are a bit cheaper. I have bought one, will receive it end of the week.
https://e-heko.com/en_GB/c/III/1502 |
Thanks I have booked on the first site you gave me the link :). Can't wait to install it on the car with also my new set of summer wheels.
