New hypermiler from the UK
Hi guys,
Can I first say that this site is fab, lots of great info to really get my teeth into, I appreciate that most of what I'm asking has probably been answered a thousand times before... I only wish the UK had such a busy hypermiling scene ! I do around 400 miles per week, so need to be fuel efficient, with diesel around £1.50 a litre ($2.35 ish) it's costing a pretty penny. I used to have a diesel fiat grande punto, which was good for 55 MPG (Imp) with a lead foot. I needed a bigger car so have now bought a Ford Focus C-Max 1.6 TDCi, it's a quite big SUV, now it doesn't have an instant MPG trip computer, so have ordered the Ultra-Gauge, so hopefully when that arrives it should help somewhat. I've been actively reading up about hypermiling on this and other sites for a while now, and must admit I'm being put off slightly about buying a diesel, as it seems that the big gains can be had with petrol, and that a lot of techniques don't work so well on diesels. I've read a few threads on this matter, but a lot of posts are written in such technical terms, a newb like me struggles to understand lol :thumbup: I understand P&G is more suited to petrols, and as my car is fitted with a DPF, I don't like this idea as it would most probably clog it up, does anyone have any suggestions. At the moment I'm just taking things steady, switching the engine off when I go down big hills etc. Also my recommended tyre pressure is 33PSI all round, and the max on the tyre wall is 44PSI, what would you go to and consider to be safe still, baring in mind the car with have a full family in it at times ! My book average figures are 57MPG, when the Ultra-Gauge arrives I hope to beat this. Anyone else got any advise ? Thanks, Paul. |
Welcome!!
THere are several tire threads. Generally everyone is runing 39psi or more. I have run 43psi on my Infiniti Q45 for several yrs. I have no problem w/ the ride or wear. |
Welcome! Ditto to Mcrew's psi advice. Maybe you could inform use as generally; how much rural, urban, suburban, etc.. is your driving?
Are you willing to use routes that may be slightly longer to stay away from multiple red lights, and courses that keep your average cruising speed lower, and fairly constant? The beauty is that the most gains don't have to be big body mods. The area between your ears, is really where you can have the greatest effect. Smoothness, finesse, behind the wheel is key. Grille blocks, and partial outer mirror size reduction, a front airdam; might be fun projects to digest one at a time, without changing the veh. drastically, or weirding out the family! Pick a spot to dig in at your comfort level. Hope to read in other sections, updates of progress as you go along. Keep asking questions, and don't be afraid to dig into older pages. The only dumb question one can ask, is if that question has already been addressed in older threads. Again; welcome! |
Hi, Paul, and welcome to EM:)
Your 1.6 TDCi is actually the same engine as in my Peugeot and Euromodder's Volvo. I'm getting some great numbers using PNG (Pulse, then Glide in Neutral, with the engine on) and haven't noticed any engine trouble (I don't have a DPF though). Euro has problems with his, but they're not directly related to hypermiling or ecomodding, iirc. Here are a few small things you can do:
Welcome to ecomodder, Paul.
Well, at least its where the drive slower part showed considerable benefit. So I kept driving slower. Those 70 mph/112kph were certainly beneficial compared to our 75 mph /120 kph. Driving slower will improve things further. Try 100 kph / 62 mph. Quote:
If you do lots of city / variable speed driving, reducing weight will help - while it hardly helps on the motorway. Ditch all car equipment you don't really need, and all assorted junk in the trunk (and anywhere else in the car). MPVs often have a gazillion of storage spaces - clean 'm out. What year is it ? Quote:
So when your driving style is altered, the gauge will also be off a bit. Many of us diesel dorks have the SG calibrated to 3/4 the displacement, i.e. only 1.2L instead of 1.6L - I had to dial in far too much compensating bias @ 1.6L . When calibrating, correct by only half the difference in total fuel used. (when the total fuel consumption is 2 L off, correct using +/- only 1 liter) Quote:
What do you call big hills ? If they're long shallow slopes, you can control speed with the aerodynamic drag and even shut the engine off (though I idle in neutral). My V50 needs about 5% gradient to keep around 62mph. If the grade is too steep for aero drag, keep the engine running and stay in (top) gear - the fuel flow will be cut off anyway in these conditions (engine braking or DFCO as it's called here) . I always keep the engine running though - steering is too hard w/o power steering, and power braking is reduced too much / too quickly to be safe for my liking. Coasting in Neutral has become my main way of slowing down. Engine braking is next, brakes are only used when the situation is unpredictable, or to come to a full stop (coasting engine-on becomes a lot less efficient the last 5-10 mph) Quote:
I'm running 51 psi (max. sidewall pressure on my Michelin Energy Savers) which is on the edge of being bouncy when running near-empty. I won't go above sidewall max. pressure. 33 psi is what Volvo (then part of Ford) recommended on my lighter V50. 44 psi is only 3 bar, and the Cmax is a heavy creature, so you can probably run 44 psi without issue. The ride will get noticeably harder, but it shouldn't get harsh & bouncy. Back off the pressure if it does bounce, that means the suspension can't cope. Fully loaded, the car will behave better with less negative effect due to the higher tyre pressure. Quote:
I can get 65 mpg Imp though ;) The grille lets in too much air - far more than the 1.6D needs - so you can close off at least the top grille, and likely part of the lower grille. The intercooler and A/C cooler will need some air though. It speeds up engine warm-up a bit when hypermiling (using less fuel means it takes longer to warm up) and improves the aerodynamics (air going through the engine bay is a drag). |
Well thanks for all the replies, all noted and very informative.
I do a 60 miles round trip which is around 50% motorway/highway and 30% main roads, 20% minor roads, hardly any traffic lights and a pretty straight run. Although I've been engine off coasting a bit, I find it a little too hardcore at the moment, roughly how much fuel do you use when coasting in neutral ? My Ultra-Gauge arrives on Wednesday according to FedEx, can't wait ! |
Extending the glide is fine with the engine off, the further you roll, the more efficient it is. But with the engine on, coasting becomes less and less efficient as you slow down. As it's also more of a nuisance to other drivers when you go painstakingly slow, I tend not to coast much below 30kph / 20mph - unless in 30mph zones. |
Thanks, note to self, don't try an engine off coast on the way home at night, because my lights go off ! lol
What you need is a kill switch for your engine. That way you won't have to turn the key in the ignition, which can be worth more than just saving the wear&tear. In my Pug, offing the engine with the key turns off many things - power steering, ECU, radio, etc. (the lights are programed to stay on for 15 seconds) - but using the kill switch keeps them all on, which is much safer.
The switch itself interrupts the crank position sensor's signal (you could also try the camshaft position sensor), telling the ECU to stop the engine. As for brake assist, there is enough vacuum in the lines for 2-3 full stops (I still had vacuum after a 6km glide). You can increase that by adding a 1-3 liter reservoir to your vacuum lines. There is a good thread here on how to make one out of PVC pipe. You could also replace your vacuum pump with an electric one, which would also reduce load on the engine (electric pump would turn on only when needed, not like the one hanging on the engine), but this isn't the cheapest of options. |
