New Invention. Electric assist. Comments?
What do you guys/gals think about the invention shown in the link below?
Fuelpup Table of Contents Page |
Sounds Good
It sounds like a good idea to me, but there sure isn't a lot of detail offered on the site. That part scares me. I also question the belt drive bing enough to motivate my 4000 lb. sled reliably.
I'm no EV expert by far, but it looks like those motors are way too small to handle the necessary current to move even a smaller vehicle let alone a Jeep. Several members have considered similar devices mounted various ways. The idea is sound, but that product doesn't look good IMO.
I don't think this system is intended to push a vehicle on its own, simply to provide assistance to the gas motor while in motion. I see no reason why this wouldn't work in fact, since I do not see any kind of controller included it is probably regulated to provide X number of rpm's giving a small boost in any gear, for us possibly a better boost when EOCing or neutral coasting.
Wish I had $1500 of disposable income to give it a try, if for nothing else to improve on it if it falls short. Bad News; It seems to be a solution for RWD vehicles only as it is part of the drive shaft assembly. |
LOL
2 starter motors with a belt around the drive shaft. I could whip up a setup like that for $100 including the machine work. It doesn't mean you're going to save any gas. |
I like the Setup, I'm thinking that those are beefed up starter motrs, or Wheelchar motors . . . .
I'm a little ticked it's patented . . . |
Reading the patent <http://www.patentstorm.us/patents/7271555/fulltext.html>
There is a reference to 1.5hp motors that *can* be found for e-bikes (and have been used with higher voltage supplies). Interestingly (numbers referencing a schematic drawing): "Electric motor 44 is supplied with operating current by one or more batteries. A first battery 52 may be the usual lead-acid storage battery that provides power for a starting motor (not shown) for internal combustion engine 12, which is conventionally located in the engine compartment of vehicle 10. A second battery may be an auxiliary gel battery 54 located in the vehicle 10 at a place other than the engine compartment, as for example in the trunk of the vehicle. However, it is preferable that the existing battery be upgraded to a high output gel cell. In some circumstances, especially for heavier vehicles, the second gel cell placed in the trunk of the vehicle should be a high output gel cell. Preferably, the alternator used in the vehicle should have an output of 100 amperes or more, achieved by replacement of the alternator, if necessary." Could one patent the plug-in option for this? (sorry, I don't have the $10k+ for a patent application... and Toyota probably has it already) |
This has to be crap. Why would you use alternator power to assist the gas engine. You are taking energy through 4 transitions with all the losses involved to throw it back inas an electric assist. If you power it from a second battery you charge... it MIGHT work for acceleration but it will never work for steady state highway driving. You car will still burn the same amount of fuel no matter what speed you are going if you have the transmission engaged to the wheels and engine.
Arminius -
Good find. It will be interesting to see if it pans out. I am a huge believer in RETROFIT solutions because we can't change the makeup of the existing American automobile fleet overnight. Ecomodder is all about retrofitting. bikin' Ed - Quote:
Electrocharger / Retrofit Hybrid :: Sigma Automotive Quote:
CarloSW2 |
In order to reach a solution that works, we'll have to endure lots that won't. ollie |
