New (to me) Car!
Picked up this 1981 Volkswagen Rabbit Diesel for 800 bucks
It has what I assume to be a 1.6l turbo diesel motor sans turbo and a 5 speed neither of which are original to the car its a 4 door no serious rust at all and its undercoated as well http://i.imgur.com/QsBz34t.jpg http://i.imgur.com/KtetCNU.jpg http://i.imgur.com/PQhlxJs.jpg Oh almost forgot it has an obnoxiously loud and poorly designed stack coming up through the trunk and out the side... not sure what I'm gonna do about that |
'81s didn't have turbos stock.
That stack shows signs of... of... Oh, just get rid of it. |
I plan on
1. replacing the rubber guards on the ends of the bumpers 2. filling in the air gap between the bumper and the car with sheets of black plastic 3. pull the dent out of the rear passenger door http://i.imgur.com/fy83oRj.jpg |
Whiskey Tango Foxtrot, who puts a stack there?
Replace #1 on your list with:
1. remove interior exhaust pipe It's extremely dangerous to route something like that in the cabin as even a small leak could cause CO poisoning over a period of time, and you might not even know it's happening. Was it a poor man's heater or something? It would have been less length of pipe to just run it out the back like sane people do. Heck, it would make more sense to pipe it straight up from the hood than into the car. |
the 1.6 NA or TD are not the same engine. don't slap a turbo on it and expect it to last. oil squirters are among the list of differences.
I had an 81. best I could get was 45 mpg, driving 55 on the freeway. there's an OD that works great on this car. Audiovox makes it. if I had no choice but to drive one again, I would: drop in a later TD, full boat tail while removing as much sheet metal to keep weight the same, swap running gear to at least 14" wheels. sure there are others but I won't drive one ever again. bought it for 1200.00 and sold it 3 years later for 1500.00 if I remember right. |
