EcoModder.com
-   For Sale (https://ecomodder.com/forum/sale.html)
-   -   New ME0913 Motor - NO LONGER AVAILABLE (https://ecomodder.com/forum/showthread.php/new-me0913-motor-no-longer-available-26269.html)
TurnNBurn 06-28-2013 09:06 PM
I have an unused Mars ME0913 motor I'm selling. I was deciding whether to keep it and go with a different controller, but I decided the Alltrax 7245 controller is what I need and thus I need to choose a different motor. It hasn't been used at all and hasn't been powered up. Buyer pays shipping. I'm also willing to trade for an ME1003.
Description:
Designed for long life. No brush maintenance. The motor is 92% efficient at voltages between 24 to 96 VDC. Continuous current of 125 amps AC (180 Amps DC into the motor control). This is a 3-phase, Y-connected Permanent Magnet Synchronous Motor with an axial air gap and 3 Hall sensors at 120 degrees electrical timing. It has two stators with a rotor in the center.
BRUSHLESS DESIGN = 0 maintenance.
POWER: Output Power of 12 KW Continuous, 30 KW Peak
Specifications
- 4 pole motor (8 magnets).
- Phase to Phase winding resistance: 0.013 Ohms
- Maximum recommended rotor speed: 5000 RPM
- Voltage: 0 to 96 VDC input to the control
- Inertia: 45 Kg Cm Squared
- Current: 125 Amps AC continuous (180 Amps DC into the motor control)
- Peak current: 420 Amps AC for 1 minute (600 Amps DC into the motor control)
- Weight: 35 pounds
- Peak Stall Torque: 90 Nm.
- Cooling: Open Frame, Fan Cooled motor
