New Member
Hi all, I'm new here. I've always had a mind for "ecomodding", but my horsepower dreams usually seem to be an overpowering factor for anything "eco" to happen...
Anyhow, I'll be lurking around the forums to learn some stuff. I hope to be getting an additional vehicle soon that will be my hypermiling machine. Being a truck guy, it'll probably be a Ranger with a 4 cylinder and a manual trans. Not much of a truck, but I think I'd prefer it over a car. I drive a 1988 F-350 4x4 XLT Lariat. Specs are as follows; 1973 468c.i. (7.7l) engine, C6 3 speed auto trans, 4.56 gears, 5" lift, 37" tires. The engine has some mods and was just rebuilt about a month ago; 0.040 overbore, "RV" style cam, ported heads, high-rise intake, long tube headers, 2.5" exhaust with only Flowmaster 50 mufflers. I average about 9 MPG, up to about 11.5 MPG on the highway. |
Welcome, truckfan!
Lots of crossover here between "traditional" gearheads and people interested in tinkering to improve efficiency. I wonder, though... if you're keeping your big truck in reserve for work duty, why not go for a project platform that has a lot more potential than an additional truck? I'm sure you've seen guys around here who are getting fantastic results from their Rangers -- far above average, for a truck, that is. But you could eclipse a Ranger's numbers (for a lot less effort/resources) with a car-based platform. cheers- Darin |
Even the F350 can already provide a decent platform for ecomodding, altough a 3-speed transmission and a big-block may not be the most effective ways to deal with that challenge.
Anyway, the first thing anyone could consider while attempting to hypermile with an old-school V8 might be trying to make it operate on the Miller-cycle, which might be not so difficult to attempt with lots of options for aftermarket superchargers and cams... |
I appreciate the reply. - Collin |
Well then, Ranger it is! There are more than a couple of projects in the forum. Lots of examples of mods to pursue. Don't forget the driving side of the equation... enormous opportunity for gains there as well ( for most people).
Your right, the 3 speed auto puts a hurting on mileage. Pretty much effects 55+ MPH highway MPGs since it doesn't have overdrive. I'd like to have a 5 speed in it for fun and for overdrive, but they were kind of rare for 460s and are hard to find in any kind of shape. |
Some best trips in other vehicles: 28.7 MPG for a 102 mile trip in a 2003 Suburban 4x4, 5.3l, 3.73 gears (Highway at about 55-60 MPH) 23.6 MPG for a 98 mile trip in a 2008 F-250 4x4 6.4l Diesel, 4.10 gears (60-65 MPH highway) 44.1 MPG for a 121 mile trip in a 2013 Accord Sport 2.4l, manual 6-speed, (60-80 mph highway) |
I met a guy once who had put one in his Explorer and was averaging 32 MPG highway. And the explorer is quite a bit more vehicle than a Ranger. |
Now that I can post pictures, here's my F-350:
http://ecomodder.com/forum/member-tr...-side-view.jpg http://ecomodder.com/forum/member-tr...next-tesla.jpg |
There's a few Rangers in the EM garage EcoModder Fleet list - EcoModder.com |
Just regrinding the cams and increasing the static compression ratio wouldn't make it operate in the Miller cycle, would only make it operate like a Prius engine, emulating the Atkinson effect. The supercharger is also required for the Miller cycle in order to overcome the discompression provided for the longer intake valve timing.
Oh, I see. So we add supercharging and a different cam and we have a Miller engine. Who hasn't done that?
I thought it was a simple weekend project? :confused:
Have you done it? No.
Have I done it? No. Has anyone here done it? I doubt it. Would it be a significant R&D effort to make it work? I think so. Do you glibly suggest the home mechanic take on projects you yourself wouldn't, haven't, or can't do? All the time. |
Sounds like a diesel swap would be much easier and you'd come out with much better MPGs, more torque, and an engine that will last longer.
After looking at what a modern 4-cyl turbodiesel is capable in a medium-duty truck I could consider a 4HK1 from the NPR or a J05E from the Hino 195 among the best options, but considering availability and emissions classes seems like the 6BT Cummins is the easier to register legally. I would recommend a Powerstroke only for an enemy. |
