EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   New member from Finland (https://ecomodder.com/forum/showthread.php/new-member-finland-20426.html)
J.A.A. 02-06-2012 04:57 PM
Hello,
I'm a new member from the cold country of Finland. I drive a 1995 Toyota Aristo, which isn't your average eco car, more like an ego car. ;)
Just reading to find some ways to improve FE. FE isn't my biggest "goal" in the car, but because I'm financially in a bad situation at the moment, I thought why not try to make it better.
larrybuck 02-10-2012 09:48 PM
I'm glad you joined us!
#1 thought was to make yourself a front airdam, add about 7psi to your tires, slow down, and drive SMOOTHLY which is hard to change habits.
I know you'll pick up alot of info here.
Can't visualize what your car looks like; maybe you could share a picture of one soon!
J.A.A. 01-06-2013 01:59 PM
tinyurl.com/bcvxcnq
Here's one.
It's basically a Lexus GS300, with a turbo engine. And it was only available in Japan.
cRiPpLe_rOoStEr 01-06-2013 08:00 PM
If your finantial situation is not the best one at the moment, I should tell you to do the cheapest eco-mod: strip its interior trim down as much as you're able to do.
As a motorcycles enthusiast, I could also tell you to delete the A/C and maybe even the cab heater. The weight of a decent jacket would be still lighter than the heater core and all its piping :D
Copyright ©2000 - 2022, vBulletin Solutions Inc.
