New member looking for aero advice Saturn SL1
I envy all of you that drive hatchbacks.
Who has an idea for how to slightly modify a sedan? I have a Saturn SL1 that I would consider modifying slightly on the rear end. The only two things I can think of are a possible spoiler on the trunk, if it was the right shape, to help with aerodynamics. Or, I've seen spoiler-like things go on the back of a lot of newer cars right above the rear window. That would be similar to a mini-camback? Right? Would something that small even make a noticable difference? |
Welcome to the site Raysp30. I would suggest you start your own intro thread. You can post all your info there and we can barage you with info. :)
Raysp30 -
1 - Studying the "Evo Vortex Generator" solution (what you are talking about). The idea would be to have vortex generators that help "bridge" the gap to a spoiler that helps your aerodynamics. Here's the Evo paper : Research on Aerodynamic Drag Reduction by Vortex Generators http://www.mitsubishi-motors.com/cor...004/16E_03.pdf But, the likelihood of MPG payoff would be much less because the Evo solution was designed for downforce (I think), and was heavily engineered. 2 - Trying to fab a removeable Kamm-Back, probably using lots of magnets. The roof and trunk lid on the SL1 is metal, so you could work with that. The key would be a design that gives you a correct shape *and* ( relatively ;) ) easy access to the trunk. If I can find a good side view picture of an SL1, I'll do a mockup. CarloSW2 |
Yes, welcome to the forum.
I split the Saturn discussion into a new thread. Hope you don't mind. CarloSW2, you're right that the Mistu VG's were designed to get more airflow onto the downforce-producing spoiler. But even without the spoiler, they had a very small positive effect on reducing Cd (though not likely enough to show up clearly at the pump). The change was less than 0.01, if I recall. |
Wheel skirts would be a good place to start as well.
Metro - No problem at all to move to a new thread.
I'm not really into hacking up an otherwise nice looking Sedan, so creating a full Kamm-back is out of the question -- even if it was somehow removeable. I'm already planning rear wheel skirts. And a partial undertray. I have a sheet of ABS Plastic sitting in my garage for when I have some extra time. I expect that to help some, but I'm still stuck with the stock body. By the way, anyone have a cd coefficient for the SL1 or similar car? |
Raysp30 -
http://img253.imageshack.us/img253/8...aturncdgx6.jpg 1997 SL1 was 0.315 CarloSW2 |
I doubt a spoiler will have much effect on aero. It looks like the 2000 SL1 and SL2 have the same CD of .32. I think the only major difference (exterior) between them is a spoiler, fog lights, and alloy wheels. Maybe an aftermarket flush/lip spoiler would be more effective, though I doubt it would be cost effective. My 1997 SC1 on the other hand, would benefit from an SC2 spoiler (SC1/.33 - SC2/.31).
I do have Vortekz brand vortex generators and smooth (full moon) hubcaps. I think I have $25 shipped (plus paint) into the VG's and $35 shipped into the hubcaps. There are pics in my garage. www.manufacturersdepot.com Browse By Manufacturer:Vortekz Category cripedistributing.com : 14" Stainless Hubcaps 81130-41 (4 pieces) [81130.41] - $18.00 |
Welcome Raysp30.If you can tell us where you're at,mpg wise,and your target mpg,that will give us a "performance envelope" to think about.Unfortunately for you,the notchback style body is the least efficient aerodynamically,however has great utility.36-percent of your future potential mpg is locked up in the air behind the Saturn.Without some changes to the back of the car,that savings will be beyond your reach.
I didn't know these rear ends were so bad. 36% is huge! Still interested in mods that would be aesthetically pleasing to the eye for a car like this. On another note, and a new post in a day or so, I'm in the process of making a permanent grill block and I just finished a front belly pan. Belly pan took a couple hours to make. The grill block is a bit more complicated. I'll start a new thread when I take the time to download the pictures. |
