EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   New Member looking for conservative improvements ('02 Maxima GLE automatic) (https://ecomodder.com/forum/showthread.php/new-member-looking-conservative-improvements-02-maxima-gle-21652.html)
Prophecy99 04-27-2012 01:16 PM
New member here. I am liking everything I read on this site, very interesting and inspiring see what everyone does on here and no judging on what kind of vehicle they have. Whats also interesting is I am more than adequately educated in designing, constructing, and maintaining environmentally sustainable Buildings and the practices associated with that. But when it comes to the advanced practices i have been reading about here, I am not extremely familiar with it when it comes to vehicles. I am knowledgeable with cars enough to have already modified my car to be one of a kind and enjoy it more than the average driver. Such as suspension, engine performance, lighting, and handling etc.
2002 Nissan Maxima GLE Automatic 5 SPD. i will post pics after 5 posts.
I am interested in getting the best(or better) gas mileage i can get with out going too far, in other words I want my eco mods to be subtle. I want to keep my car fairly the same on the outside, which may or may not be my down fall to actually reach my 28-30 mpg goals. EPA 17 city 24 Highway. Which I have read in the Maxima world people with autos can get up to 22 city 28 highway. on average at best.
Recently i have been driving wholly concerned with only minimum fuel consumption (fc) in mind. Never going over 2,000 rpm, and staying under 60-65 at high way speeds.
I recently have been manually tracking my MPG (since the ECU is usually ambitious to the point of 3-4 MPG higher than actual) and have gotten at best so far on 90% highway trips 23.78 mpg. Which isnt bad considering that was also before I changed my so called lifetime fuel filter. It is known in the maxima world that changing this fuel filter is recommended even though its supposedly lifetime. I am really excited to see how the change helped. By judging how much I have traveled on my current tank after the fuel filter replacement alone I can easily say i got 2-3 mpg better. Will post updated mpg from that tank.
List of Eco related Mods
-Lowered 1.4 all around
-42 PSI all around
-Driving Habits modifiied/regulated for best MPG at all times
-Regular Maintenance done (ngk platinum spark plugs, filters, fuild changes/flushes, all with in 15k miles)
-Front Lip Spoiler
-No rear spoiler (dont no if bad or good for eco)
-No aftermarket exhaust, or air intake
What are some other things I can do to reach my conservative 28-30 mpg goals? I know my air filter could be changed but i have been blowing it out every so often.
Some things that caught my eye are under body aerodynamics, grille blocking, and rear diffusers. All pretty subtle if done right. i also have a grounding kit, which has helped idle, shifting, and electronics very nicely.
Thanks in advance for any info or advice!
Prophecy99 04-27-2012 01:22 PM
another eco mod I just noticed I have
Advanced Ignition Timing 2 degrees.
I also use 89 octane, and IIRC octane usually dosen't effect mpg as long as your engine isn't pinging.
MetroMPG 04-27-2012 03:02 PM
Welcome to the forum.
Believe it or not, a dirty air filter will have a little to no effect on fuel economy. Long gone are the days when a dirty filter accidentally resulted in an enriched air/fuel mixture (pre-computer monitoring - e.g. OBD). Even with a dirty filter, at part throttle openings (ie. at low/mid load engine operation), the throttle plate is the major restriction.
Those all sound reasonable. I'd start with the partial grille block (easiest), and monitor engine temps as you progressively tune it for best effect. Do you have a way to accurately monitor coolant temps (digital gauge)?
Prophecy99 04-27-2012 03:47 PM
that's amazing i never heard that, you always hear advertisements and the auto communities stating a dirty air filter is bad for your mpg.
Also i have a good feeling my butterfly valve of the throttle body is dirty and shows all the specific symptoms of it (immediate surge of rpm after cold start ups, and goes back to regular idle rpm shorty after, and a medium rough idle in traffic and Park). Do you think that would effect mpg?
I have a engine coolant temp gauge, so yes i can monitor how the blocking works. My quesiton with grille blocking is is it still effective if I put it directly behind the actual grille and infront of the radiator etc? In other words I want it to be subtle and not directly on the outside of the car. Again aesthetics on this car is more important to me than a few % of aero. I would think any kind of block is better than nothing.
Thanks for the reply. I am starting to see you're posts everywhere.
MetroMPG 04-27-2012 03:53 PM
Blocking directly behind the grille will work nearly as well as in front. Some members do just that for aesthetics.
As for that throttle plate, makes sense that a clean intake would perform best in all regards.
I'm a bit surprised that you're only getting 24 mpg while keeping your speeds down to 60-65. I'd think you'd be exceeding highway EPA by ~5-10% at that speed (assuming you're doing 90% highway).
allenh318 04-27-2012 08:05 PM
Try changing oil to a synthetic and go with the 5w-30, which I believe is what your car recommends. Can also go with synthetic trans fluid, check all brakes to make sure they are adjusted correctly and not hanging. While checking brakes, check bearings and axles greased properly. Next, you can seafoam the engine to make sure your fuel inj is working properly. You can also spray carb cleaner on the throttle plate if you are concerned about it not working properly. I have a '95 Maxima GLE, did all of these mods as well as complete tune up, and get 26-28 regularly out of it.
GRU 04-27-2012 10:50 PM
check your wheel alignment
allenh318 04-28-2012 07:04 AM
Good point on the alignment, also pump your tires up to sidewall max and possibly get low rolling resistance tires, that should not change the look of your car much.
Prophecy99 06-11-2012 01:35 PM
Update: got a wheel alignment, mounted balanced all tires.
I am running on heavy aftermarket 18" wheels but i like them too much and am willing to take the little downfall from them, which I don't really see much. I only use them in the summer months and the blends fuel in the summer months make declines in efficiency a wash.
I have been gettin 24.8 MPG and 24.9 MPG on a few tanks now with 50/50 city highway. I am quite happy seeing 25 mpg but would like to reach 28-30 if at all possible with a 50/50 city highway run.
I also have a rear brake issue with them making contact at all times, so that has to be hurting too.
Prophecy99 06-11-2012 01:37 PM
do you guys think going from 42 PSI to 44PSI will really do anything?
i am also researching under body aerodynamic material to make a rear diffuser.
MetroMPG 06-11-2012 02:16 PM
The car will roll marginally better, but 2 PSI is too small to see a measurable difference. EG see: http://ecomodder.com/forum/showthrea...tml#post265379
Question about your big rims: has your overall outside tire diameter changed from stock? If so, how much and are you correcting your fuel consumption calculations to account for it? If your outside diameter increased, your odometer will be under-reporting distance, making your MPG calculations appear worse than they really are.
Prophecy99 06-13-2012 08:00 AM
believe it or not the 18" wheels that I have are a smaller diameter than stock (17"). Due to the smaller rubber band tires(225/40/18) its 3% smaller in over all diameter.
Once i upgrade the tires to (235/45/18) I should be within 1% difference to the stock setups in the winter. My main gripe with them are the weight, I can imagine the weight difference is.. more than the diameter in this case.
Once i fix my rear brake issue, I am going to get into the rear diffuser.
I just hope my dreams of 28-30 MPG is possible one day.
By the way I am driving right now I dont see how I can get it much better from the 24.9 MPG right now.
Sporty Modder 06-13-2012 09:30 AM
I dont know how I missed this. I have a special place in my heart for Maximas.I had a 97 man trans, and gained some mpg from lowering the car 1" all around. This lowers frontal area and reduces drag. After that I got my best hiway mpg of 31. I also had a Stillen body kit, and no spoiler. I also ran premium fuel when I put 87 in it I typically lost 2-3 mpg.
Found the curb weight on msn cars, 3218 and width 70.3 height 56.3 subtract 1.4" 54.9".
Prophecy99 06-13-2012 04:05 PM
I agree they are great cars, I am lowered 1.4" all around
i should search for this on here but I always thought octane doesn't effect mpg as long as it doesnt make your engine ping (retard the timing so much it pings).
Sporty Modder 06-13-2012 04:16 PM
Just my experiance my Maxima, Altima, and Celica were/ are sensitive to premium where my F150, Suburban, Prism, Towncar were not. I think it depends on the car, the only way to know for sure is to test it.
Prophecy99 08-21-2012 08:21 AM
update
I switched to Premium 93 ocatane, and fixed my rear dragging brakes.
Went on highway trip with 25% mixed city driving for vacation and its not exact but conservative numbers are 27.6 MPG.! Which feels really good to see. 28 MPG seems really close! I just finished installing a rear diffuser and hope to see some results soon. just have to drive :thumbup:
Prophecy99 12-07-2012 01:31 PM
an update during sept 12'
I reached 28.18 MPG on a trip to the mountains loaded with 3 people and AC on!
i dont know how but... i guess the rear diffuser, windows up, and cruise control speed helped.
now on to the winter blues....
mcrews 12-07-2012 02:05 PM
what a great way to head into the cold season! congrats!!!!
Most of the trips I logged across country )Sato ca to DaLLAS tX) WERE WITH A loaded CAR. (clothes and stuff)
I really think that if just me, I could have gotten 33+. (driving 60mph)
and I always left the a/c on 'auto'.
Prophecy99 12-07-2012 02:23 PM
Thanks buddy, It feels good to reach a goal. Hopefully next summer I can reach 30 MPG like u. Sometimes i switch from auto to econ, it obviously gets hotter but sometimes is bareable espcially when ur moving and can get the fresh air that you are driving thru. Sit and go traffic econ is horrible. I ususally switch back and forth from auto to econ.
I think we have the same nissan ACC Automatic Climate Control unit.
(update: I also read in my nissan manual that when set on auto 80 deg is the most effecient according to them)
Which on a really hot summer day if you set auto to 80 it still is cold... i thought that was interesting.
mcrews 12-07-2012 03:05 PM
Remeber, I went up to 245/50/18, about 6% over stock.
Also, I was around 1850rpms. I think you in the low 2000?
