New Saturn-driving member
Just a note to introduce myself. I just joined the forum. I bought a 1996 Saturn SL 5-speed a few months ago that I have had reasonable success with in it's bone stock form. In the warm months I can keep the average above 40 mpg. Winter sucks it down a bit. I am following with interest some of the ideas for efficiency modifications and driving techniques found on this forum. I don't plan any radical mods, but my mind is open to what can be done within reason.
Welcome to ecomodder. You got a great starting point for better economy by owning that Saturn! Those cars get great MPG's
I would start by reading these............ 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com 65+ Vehicle modifications for better fuel economy - EcoModder.com |
Nels -
Welcome to EM! Whenever I see an unpainted Saturn bumper, I think, "Oooooh, I can get great MPG in that Saturn". Bone stock with a manual tranny is the way to go for MPG. Are you lucky enough to also have manual steering? CarloSW2 |
There's a 97 Saturn SL as plain as this one at another local lot with only 84,000 miles. We may become a two Saturn family soon. :D |
Welcome to Ecommoder.com.
Make sure you use the MPG tracking utility to log your gas fillups. If you are interested in reducing belt/pulley drag, consider running without the alternator. I installed a larger battery in the back of my Jeep TJ and ran without the alternator everyday to work. Once, I came home, I simply recharged with a $20 battery charger from Wal-Mart. |
1 Attachment(s)
Welcome to EM Nels.
My neighbor had an SC2 of comparable year. He, while not being a ecodriver necessarily, always got very respectable mileage out of it. I can only imagine a little tweaking could have you getting great mileage. Nice to see another cheese head too. :) |
Power Steering Delete.
I (and a few others here) have deleted the PS. (97 Mazda Protoge) I just looped (hooked together) the input and output ports from the stearing gear. I kept it about half full of fluid. This way as I steer I get some PS fluid moving through the system. If you fill it too full then nowhere for it to go when it gets hot and expands. Others claim you need to just cap/seal the input and output ports. (There is enough "slosh" to keep everything lubricated.) Still others go the whole way and change out the whole setup with a non-power steering setup. The steering force in my opion is the same as my non-powersteering small toyota PU. You may have problems in the parking lot/parallel parking if your wife drives it or you have shoulder problems. Maybe try the loopback method first and if you are stuggling to steer then change out the gearing. I manually entered fuel log from Mazda (Only owned two years). I'm waiting for an automatic way to upload for PU. (I have 275 tanks over 15 years of data) -- My inner geek. ---Welcome. |
Nels -
This morning I complemented a dude that owned a bone-stock 2nd gen SL(1?), stickshift, grey metalic paintjob with the no-paint bumper (a complimentary color combo, IMO). I directed him over to saturnfans.com for care and maintenance. I could tell that he was both happy and confused at the same time, :D . CarloSW2 |
Nels -
rgathright - If he does join saturnfans, I will use the power of the farce to turn him to the Green-Side (insert Darth Vader breathing sound here). CarloSW2 |
