Old 10-11-2010, 12:45 PM   #1 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 Toyota pickup plain
90 day: 32.08 mpg (US)
Whoo Hooo! '97 Tercel
YAY I have returned with a new (to me) '97 tercel to mod the hell out of!
I'm eagerly awaiting mods to see what I can eke out of this baby!
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 10-11-2010, 01:13 PM   #2 (permalink)
Congrats on the Tercel. They're great cars. It has the same engine as my Paseo (along with many other parts). With no mods and good driving (P&G) technique I was able to hit 59 mpg. After I started modding my best tank has been 70 mpg.
Old 10-20-2010, 02:52 AM   #3 (permalink)
penny pincher
kevlar's Avatar
I've got my car de-teened after a few weeks of cleaning, new brakes, and new rear wheel bearings. I test drove it to work today and also realized the struts are gone, sounds like ball joints too. But what bothers me is the front (diff?) is making a loud hollow noise. Since the kids were so kind as to loose the owners manual I have to wing it on many things.... such as;
where do I check the Diff fluid?
Is there anywhere to get info on inspecting/changing front wheel bearings?
The motor smokes like a hooker after a trick until it warms up! Valve job? Is it worth it?
how it was done...
Old 10-20-2010, 04:27 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Congrats on the new ride. One of my friends over here has a tercel and despite the fact that I am about 6 inches too tall to sit up in the back seat, it's a sweet ride.
Old 10-20-2010, 07:11 AM   #5 (permalink)
There is a pipe plug on the front of the transmission. Unscrew it and stick your finger in there. The oil level should be just below the hole. I highly doubt you have a leak though. I've never heard of one leaking.
Its pretty easy, I had to replace one on my Paseo. Take off the wheel, rotor, unscrew the drive shaft nut and disconnect the rest of the stuff from the hub. Then just take it in to have some place press out the bearing and put a new one in with a new seal.
That would be the valve stem seals. They are a pain to replace without taking the head off.
Old 10-20-2010, 11:39 AM   #6 (permalink)
penny pincher
kevlar's Avatar
Sounds like I'm about to have a winter project...lol
First it's off to get the anti-eco project done; putting a lift kit and headers on the GMC.
how it was done...
Old 10-21-2010, 12:16 AM   #7 (permalink)
penny pincher
kevlar's Avatar
Change of plans for me. It's off to stop the oil burning instead! Going in for the valve seals!
Got the terc on stands and I have torn into the top cover.
I am now at the point of timing belts, tensioner and removing cams. very lost here. How does one remove the timing belt and Pull the cams? I have the gears clearly marked already, waiting for guidance on this....
(I'm making a log with pics on this for posting as a how to for doing 1.5 valves and guides)
how it was done...
Old 10-21-2010, 07:18 AM   #8 (permalink)
If you want to get away with the minimum amount of work, just pop the cam timing pulley off and remove the caps on the cam journals.
Old 10-21-2010, 12:50 PM   #9 (permalink)
penny pincher
kevlar's Avatar
Thanks for the help. I'll try that. I wasn't sure if there was a tensioner that needed loosening.
Old 10-21-2010, 01:02 PM   #10 (permalink)
It shouldn't be on that tight.
1996 Toyota Tercel Ecomodification Toby EcoModding Central 30 11-08-2011 08:07 AM
Thinking about a Tercel diesel engine swap Daox EcoModding Central 23 07-21-2010 04:18 PM
1997 Toyota Tercel Turbo Diesel (Surrey BC) Daox For Sale 15 06-01-2010 08:32 PM
'97 Civic running 14.2 Volts? brucepick Off-Topic Tech 8 02-09-2009 10:31 AM
