Old 04-19-2009, 11:26 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Single Wheel Hybrid Trailer concept
With all this talk of EV pusher trailers and other ways of having an "instant-hybrid", it got me thinking.
Today, I was talking with the guys about testing out an EV system, so as to have the whole drivetrain and electrics all worked out before installing it in a vehicle quickly, like doing a weekend conversion.
One thing we joked about was to bolt it to the 2" hitch receiver on the back of a pickup truck. You could just put all the batteries in the bed of the truck, and everything else could just be connected as a single unit into the hitch receiver.
If this was integrated as a one-wheel trailer, it could act as a hybrid system.
It would be similar to the Honda Insight 5th Wheel, only just be a bolt-on system.
Add a couple of turn and stop signals to it, and it would qualify as a trailer.
I think this could work pretty decent on a pickup truck. I am not sure exactly how it would need to be setup for steering and tire wear. I would also imagine perhaps a way to raise or lower the fifth wheel, so that it would not over-rev and EV motor while on the freeway.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-19-2009, 11:28 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Do it!
Old 04-19-2009, 11:32 PM   #3 (permalink)
The "steering" situation could be problematic.
One wheel trailers "caster" that wheel. Right now, I don't see an easy way to put power through a castering wheel, especially if it sees torque in both directions i.e. regen capability.
The location of the wheel out behind the rear axle by that distance would make steering or castering a necessity I would think. Perhaps a linkage could be affixed to the chassis for steering? It's an extra complexity but surely not insurmountable. The plus side is, it could have some boattailing bodywork.
Or, since trucks are usually so high up, the receiver mount could extend forward instead of backward, positioning the wheel as close to axle centerline as possible. That might minimize scrub to a degree that allows a fixed non-castering/steering mount. I don't know. Tucking all that stuff underneath would probably cause problems too.
Two wheeled trailer starting to look good again. :/
Old 04-19-2009, 11:32 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Why not? I'm thinking about making a trailer that follows a tear-drop shape from my van's roof line, so maybe I'll get better mileage towing the trailer than w/o it! LOL.
I say go for it!
Old 04-19-2009, 11:48 PM   #5 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Ah, here's somthing similar to what I was thinking.
E-wheel for any vehicle - MIMA Honda Insight Modified Integrated Motor Assist
Perhaps a chunk of motorcycle might work well?
Tucking under the back of the truck would help with the swivel/steering issue. I'm just tossing some ideas out there.
A while back, I was thinking about converting my S10 to hybrid electric, but there are a lot of little things that can make it problematic.
I like the concept of an EV trailer, but electric is best for in town and slow speeds - times when I would rather NOT be towing a trailer around!
A smaller device that could mount on the truck and still be easily removable when not needed would be a great experiment.
My YouTube Videos
Old 04-19-2009, 11:53 PM   #6 (permalink)
I'd like to see that pusher wheel in action. It just looks.... like it would be clunky, or wear that tire down in no time, or just plain break.
Plus, doesn't it make sense to have the batteries with the wheel unit? When wheel unit is off, so are heavy batteries.
Old 04-19-2009, 11:54 PM   #7 (permalink)
For a truck, a rear swing-arm from a bike w/ either a hub motor or an e-motor chain-attached to drive it...
Use the whole swing-arm, weld in a frame w/ a piece of square stock that will fit your specific class of hitch (class III, to be safe, I'd think, at least for starters). Drill the square stock so that it can be pinned into the hitch, and will still touch the ground, but allow it to be pivoted up and down. (Manually, at first, automatically, once the theory is proven and prototyped.)
The whole setup, given parts and nominal dimensions, would make an S-10 about 3 ft longer. Hardly something to complain about.
Old 04-19-2009, 11:57 PM   #8 (permalink)
Until you want to turn it.
Old 04-20-2009, 12:03 AM   #9 (permalink)
Given an initial test, turning shouldn't really be an issue. Unless you're just looking for something to be obstinate about...
Old 04-20-2009, 12:16 AM   #10 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Use a u-joint to let it move up and down and side to side without being able to twist.
Works for single wheel motorcycle trailers
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 41 10-14-2019 10:22 PM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Homebrew Hybrid concept. Would it work? bennelson Hybrids 12 04-30-2008 03:30 PM
