New study shows 0 impact of a clogged air filter on fuel injected cars
From EPA site:
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf It was instead (obviously) on carburetor cars. |
THANK YOU THANK YOU THANK YOU!
I've been telling people this for years, and they have been telling me I'm wrong for years citing those cards on parts counters as evidence that I am wrong. |
I always thought this was mostly obvious...
It's the reason I don't change my air filter, or just don't use one (instead, I use a T-shirt.) |
In carburated cars, a clogged filter alters the air/fuel ratio and degrades both performance and economy. |
...ain't it wonderful that computers are able to "correct & compensate" for lazy car owners (wink,wink)?
So, does this also have a corollary effect on the discussions of ram air, and warm air induction?
This would only be true for non turbo gas engines I belive. So keep your airfilter on your diesel og turbo car in good shape - clean that is!
negative boost is negative boost, regardless of the engine type. The only difference is the carbed cars don't dynamically adjust fueling, that's all.
All this study is saying in the end is that even if your filter is clogged, the negative boost is never enough to have a significant impact on fuel economy when driven in normal conditions. A free flowing filter is always better, but so marginally better it's insignificant. Ram air reduces, and can even negate, negative boost, but again it's not much significant under normal driving conditions. WAI has ramifications in the combustion process itself so it's not just about negative boost in that case. |
This makes perfect sense--The AFM only measures that comes into the unit through the filter, clogged or not. The fuel trims will adjust for the airflow and not be effected by the restriction before the monitoring device.
...of course, all this "adjustment" is predicated upon the precision of the incoming measurement(s)...which are usually "close enough" at their design-center, but certainly NOT so at the edges/limits of their operating "ranges."
...Flex-Fuel vehicles, with their much WIDER-range sensors and computer algorithms, will probably be affected by this much LESS than the remaining 85% of the cars on the road (pun intended). |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
