New things: Tribologism and the Blue Whirl
Sounds like zddp
What Ever Happened To Smokey's Hot-Vapor Engine? - Hot Rod Magazine It's held back by metallurgy. Maybe 3D printed ceramics is the answer. At the very least we learned a new word: https://en.wikipedia.org/wiki/Tribology. Quote:
This is a coating, not unlike other aerospace coatings, except that when it wears it exposes a catalyst that steals ions from the motor oil to repair the wear. Wear on the underlying metal part is immeasurable. If this comes to market, I want to build up one more 36hp VW boxer from the case I'm hoarding. |
In this case they use superdupercomputer modeling to understand what's happening at the pressures experienced at the point of contact. Quote:
Old Tele man -- Instead of deleting posts you could just replace it with [this space intentionally left blank]. |
Whoever is trolling Old Tele man should stop. Not in my thread.
I don't think this is worth a new thread, but these guys have the money to recreate the first real airliner the Handley Page HP42, and they are going to do it: UK team plans to build replica of 1930s aircraft that frequented Sharjah | The National We're talking 9 tons, 2000hp and 120mph top speed, but for a fixed gear biplane that's pretty good. Wood paneled interiors; probably a Zepplin-like experience, smaller but not much faster. The V-shaped struts means there's a little lift mixed in with the drag. Imagine if they were a 3D printed metal foam. And the engines had fireball combustion chambers and self healing diamond coatings. |
And I thought that tribology was the study of tribes.
https://www.youtube.com/watch?v=VM1f0RKQtmc :p > |
