New in "Tools" menu: Fuel economy units conversion calculator
I love that there is now a "Tools" feature next to the Garage.
Could we get a "watt-hours per mile" added to the fuel conversions calculator? Doing all this myself on paper is a bit discouraging (too much math!!!!) Designing it into the calculator would encourage EVers on the forum to use the fuel log more, as well as put everyone on an even footing, since we would all be calculating MPGe the same way. |
Great idear. Will do.
I've added Wh/km and Wh/mi.
I really should add Gal (US) / 100 mi as well... |
Another Feature to add to the Tools menu...
1 Attachment(s)
I thought this might be a good addition and just finished touching up the HTML
Gear Speed Calculator: Attachment 2513 Just convert txt to and HTML page and she's good to go. |
BUG in calculator!
Thanks for adding the "Watt Hours Per Mile" into the calculator tool.
However, I have found a bug in it. It seems to work fine converting miles per gallon into watt-hours, but not so good converting watt-hours into miles per gallon. Usually, if I go straight to the calculator (no info entered in it yet) and put in a number for watt-hours and hit CONVERT to see what it equals in MPG, it will come up as ZERO on some of the boxes and INFINITY in others. When there is now data in the other boxes, and I change the Watt-hours to something else, it sometimes comes up with the correct number in MPG and sometimes comes up with something TOTALLY OFF, like 8 mpg http://gallery.me.com/benhdvideoguy/...20calc/web.jpg It also gives different numbers depending on if I click on the convert button or if I just hit the TAB key to update! I tested this in Safari 3.2.1 and Firefox 2.0.0.20. I also noticed that entering the same # in WH came up with different MPG #s in the two browsers. I love the idea of using this calculator for electric to gas conversion, but it still needs some work! |
Thanks beta testers! (muffled GRRr)
Rather than fight with javascript compatibility across browsers, I'll probably just recode it in php. Expect an update sometime in 2010! ;D |
Should be more reliable now. Have a go: Fuel economy conversions - EcoModder.com |
yep, seems to be working better.
Looks great! Any chance of getting the US Gal/100 mi?
Great! This is a fun calculator.
I have noticed that if I make my entry into wh/mi the converter will change my entry a slight amount.
Example: 164.7 wh/mi entered converter changes the entry to wh/mi 165.93 when you hit convert. I'm guessing it is doing a rounding method of some sort to allow for the other parameters, curious what it is. Or is this not suppose to be happening? Thx for any info.:thumbup: |
You're right that it's a rounding issue. I'll look at the code and see if there's a quick fix.
Fixed - try that.
PS ... Quote:
I have an issue with the fossil fuel/electricity conversion in general.
I take it that you're comparing the caloric value of both, not the actually produced power on the road. Gasoline engines are hopelessly inefficient, converting only a small part of all the energy into movement. EV's on the other hand use almost all of it. So I enter a real world comparison; My Insight II will do 5 l/100 km @ 120km/h under good conditions. According to the tool that's 443.25 Wh/km; in an hour it will need 53190.56 Wh/ slashing the hour away, a constant power consumption of over 53 kiloWatt. At first this seems strange. This is very close to the max power output of the engine. how can it be then that the top speed of my car is over 180 km/h? Then I realise that the 53 kW is the car's power consumption, not production. When it produces its max 66 kW or so it will use over 250 kW worth of gasoline, wasting almost 200 kW to heat. And yes, the tool mentions consumption not production. It does what it is supposed to do. However, to search out how much kWh I'd need to get an acceptable range on an EV by comparing the gas FC for a comparable car, or how much gas I'd save by converting all my lights to HID and LED, I must base my calculations on output power production. To convert fuel per distance to output power you need to estimate the efficiency of the conversion, what type of fuel is used, what th driving conditions are and the engine load; as lightly loaded engines burn inefficiently, even while attaining good mpg at the same time. In the case of HID and LED conversion I even have to account for losses by the alternator, as that provides the electricity from the output power of the gas engine. My estimate was that every kWh of electrity usage reduction would yield at least half a liter of fuel savings. Electricity produced by a gas powered car is way more expensive than electricity from the wall. If it weren't then EV's would have no right of existence. Of course, real world figures show that an EV's power consuption costs per mile are just a fraction of that of their gas powered cousins. Having said all this, it is possible to take all these factors into account recalculating them on the result. In the LED conversion case I even just need the table. So to save 1 litre fo fuel burnt at 20% efficiency (running partial load) and converted to electricity by a 70% alternator it takes just 14% of the 8.87 kWh specified in the table so just below 1.25 kWh. When I drive my HID kit and license plate etc. LEDs will be always on (for safety), a 50 W reduction to the original lighting. In 25 hours of running that will save me a litre. I do about 60 km/h average speed overall and achieve about 5 l/100 km so I use 3 l/h. This conversion wil reduce my FC by 1/75th or about 1.333 % Just running LED DRL's would double the gain: - 100 W or -2.666 % FC. In Holland gas is more expensive than Heineken (per volume, supermarket prices). I will earn back my investment within a few years. |
If I enter anything in the km/gal field the calculations go ape...
it yields weird results, or none at all. |
I am stonkered. I'm 69, and grew up on Imperial MPG. Knowing that U.S. quarts were 32 fl.oz. to our 40, I had always converted 40 MPG to 32 MPG-US. Today, I was playing with my new metric calculator, and eventually deduced that US fluid ounces are based on alcohol rather than water. Checking in here confirms that I should have been calculating 33.31 MPG-US. This clears up a long-nagging suspicion that someone was fudging. However, if a gearhead like myself got it wrong, I'm sure I'm not alone.
