New user intro and pick-up aero modding
1 Attachment(s)
Hello everyone!
I've recently been linked to view one of the forum members work on a civic and found this forum that way. Let me just say that would have probably joined this forum a long time ago had I known it existed, I am definitely into some home brewed radical solutions to problems in order to maximize performance. I have experimented with aero modding of a car quite a bit, only from a different angle, namely adding downforce to my old racecar. But, as I see it, modifications done to the car to improve gas mileage isn't that far off from stuff I've been doing in the past and I am ready to tackle some aero work from that direction for change :) . And without much more introduction let's go straight into the depth of the brick that I'll be driving soon. I'm currently looking for a used Toyota T100 to replace my gas chugging GMC Sierra 5.3L V8. I needed the GMC at the time for towing and work but the needs have changed and I'm now looking for a T100 4 cyl / 5 spd to replace it as I still need that size of PU for work. Nice thing about the T100 4 cyl (aside of the legends about it living forever) is the relatively good gas mileage of 21 city /25 hwy or so, but, since we're here to discuss aero-modding than here are some of my thoughts - * An aerodynamic shell, shaped like the back of my wife's 05 Prius. * Moondiscs on the wheel, subject to verification of sufficient cooling for the brakes. * Streamlined wheel well at the rear with the aid of a cover, attached with recessed bolts or nuts (whatever will be easier to fabricate). * Partial smooth bottom and/or front air dam. Comments, questions or any other piece of info will be appreciated! Moti BTW, before someone asks - Yes, I have searched the forum and yes, I just saw the aerodynamic Toyota T100 that was already built... funny how someone had the same exact ideas and applied them to the same exact truck. :cool: |
Welcome to the site! I won't pretend to be a truck aero guru, but it looks like you're off to a good start.
Got a scangauge yet? |
I better get the truck first (I'm searching for one in the last couple of weeks).
For the current truck I'm not sure if I really want to know :eek: Moti |
Hi, Moti...
Another consideration when you're shopping for your T-100 is choosing the model year. If they made them in 1996 or later, that's what I would look for. It would permit you to add a ScanGauge so you could monitor your instant/average fuel economy to adjust the nut behind the wheel & determine the in/effectiveness of mods. (As well as a multitude of other features it's good for.) Quote:
Good luck truck shopping! Darin |
Thanks.
With the T100 I'm pretty much stuck to whatever I find, there really aren't enough of them out there to be picky about the year too. It's just another bit that limits the amount of trucks available FS, which I have already limited down with the fact that it needs to be a 4 cyl (most of them are V6), 2WD when there are a lot of 4WD's, Long bed (eliminates the Xtracab trucks) and manual trans... Not a whole lot of them left after you take mileage and price into account. Hopefully I'll find one that I can hook up the scan gauge to, but I won't be turning a nice 93-95 truck away because of it. Moti |
