EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   New user from Tulsa - Monster fuel user (https://ecomodder.com/forum/showthread.php/new-user-tulsa-monster-fuel-user-26440.html)
csharpe3 07-21-2013 12:17 AM
Greetings,
So, I have a few vehicles. I can't say that Hypermiing was high on my list of things to do.
We had a Minivan, I sold my Focus and bought a BMW 325i, On recent trips I discovered that it is just not very comfortable for a family of 6. ( only had four in the BMW) Bought a monster, 2002 Ford Expedition. My first tank made me sick, 10mpg, followed by my second tank at 9.5. Something had to be done. I read this site and others changed my driving style and Tuned up the Ford. I reached 13+ on this fill up. I will be tring other tactics and playing the "Game" with a instant MPG meter. I ordered a wireless OBD2 adapter that works with my iphone. I can't wait for it to get here to learn more.
I also would like to buils a boat tail like on some 18 wheelers to see if that helps on a long trip.
oil pan 4 07-21-2013 02:47 AM
Yeah that must be the gas powered one.
Lets see what I can find...
Edit:
http://ecomodder.com/forum/showthrea...ne-6575-3.html
http://ecomodder.com/forum/showthrea...ban-23046.html
14mpg to 20mpg with no aero mods:
http://gasbuddy.com/Forum_MSG.aspx?m...ge_no=89&FAV=N
MetroMPG 07-21-2013 12:31 PM
Is going back to the minivan not an option? You could pay for one in fuel savings!
/captain obvious
mcrews 07-21-2013 09:05 PM
thuoght this said "New from Tesla...."
I was a little disappointed.....
But WELCOME!!!!
CrazyLee 07-21-2013 11:57 PM
Originally Posted by csharpe3 (Post 381376)
Greetings,
I'm sure that we all have had the monster fuel gobbling vehicle. There many tips on this forum to get better fuel mileage. Here are a few things I do to get The Beast motor home to get 15-16 mpg.
First buy a good fuel mileage meter if one isn't already in the vehicle. (I installed an MPGuino + JCar module.)
By keeping the actual fuel usage on the meter higher than the average mpg reading ensures that your fuel mileage is getting better.
Make sure the engine is in a lean burn condition. How? By lifting the throttle and pressing it back down. This forces the ECU to set the engine into lean burn. Look and see how much more the MPG meter went up. You do not have to lift all the way either. Monitor the meter often, but keeping your eyes on the road. Safe driving is paramount.
When approaching a hill press down on the accelerator ever so slowly so the lean burn condition stays "in". Try to gain 5 mph. Now, hold the throttle very still and you may crest the hill still in lean burn. This saves a real lot of gas! Always lift the throttle when cresting a hill. Coast downhill a much as possible, not losing too much speed. (Most EFI vehicles shut off the injectors during a Coast @ over 50 mph.)
You may find other tricks to driving efficiently. Just pass them on.
I am now getting 15-6 mpg on my motor home "The Beast" It's in my garage.
Sporty Modder 07-22-2013 07:51 PM
It seems everyone has a beast, lol. My 92 suburban best tank no mods was 16 mpg. I regularly got 15+ mpg's didn't drive it alot because of the terrible mpg's. Hardly filled it up because it took $12-$160 to fill it. My Celica doubled my mpg's. Just something to consider pick up a $500 beater and save the Ex for when you have to haul the family. Smart driving, aka no exesive accelerating50+ psi in the tires planning your trips for shopping ect... can get you 16+ mpg I am sure.
350 v8, tbi f I, 4x4, pt trans case.
CrazyLee 07-22-2013 08:51 PM
Those little cars do help us a lot on fuel!
My 2000 Venture van, bone stock, usually gets 28 mpg. Earlier in July I purchased a DashDyno SPD from Amazon and got the used one they offered. The purchased was justified on the next weekend as my wife and I drove to Detroit for a Tigers ballgame. (3 hours drive one way!) My usual 28 mpg jumped up to an actual 38 mpg on the next fill up! :)
The trick is to put the fuel meter to use and refine your driving style to enhance the fuel mileage. It took me about a year to get up to 15 mpg on my motor home, up from 10.5 mpg. That's a sweet 50% improvement. I used what I learned on the RV to get the 38 mpg.
Cheers, CrazyLee
CrazyComputers - Information about your Computer
lordherald 07-22-2013 09:15 PM
Well at least you have the benefit of Tulsa being relatively flat. Is your Expedition 2x or 4x?
WE3ZS 07-22-2013 10:38 PM
I would think your little V-8 Expedition should be able to do better than that 13 MPG tank, my V-10 Excursion 4X4, 4" lift with 4.88 gears can give me 14 MPG highway and about 11 to 12 around town using a few of the hypermiling techniques found on this site, nothing crazy just a lot of coasting and close watch on the Ultra-Gauge. Before I swapped to the deeper gears I had 3.73 gears from the factory and could get 15.5 MPG highway with a full load (8) of adults on board. Earlier this year I was able to average 9.0 MPG comming from Savannah GA to Philly with 5 adults and gear while pulling our high profile 9500lb ToyHauler camper. Kept speeds between 63 and 65 MPH and worked the throttle to keep the trans in OD all the way.
I know 9 MPG is a pretty low figure to be bragging about on this site but considering the vehicle, load (18,250lb CGVW) and aero I'm pretty happy with it. Prior runs along the same route with the same load and the factory 3.73 gears were about 7.25 MPG.
http://i1255.photobucket.com/albums/...pse5c76d93.jpg
cRiPpLe_rOoStEr 07-23-2013 03:07 AM
Which engine does it have, the 4.6 or the 5.4? BTW have you never considered to make it run in the Miller cycle?
