Old 06-12-2008, 06:04 PM   #1 (permalink)
Goldenfrog's Avatar
Tires with different max PSI
I have 2 different brands of tire on my car. They are all the same size but have different max PSI ratings. The front pair have a max of 44 and the rear set max is 35. I had them inflated to max with Nitrogen today, 44PSI front and 35 PSI back. I was wondering how this might effect safety and MPG of my car.
It's a 1993 Plymouth Voyager with a 2.5l 4cyl. 95% of my driving is under 35mph, short trips where the engine never really warms up. I am guessing under these conditions I'm not going to see any difference in MPG.
I was thinking of trying a hot air intake but I'm unclear as to how that works. I always heard that your car performs better with cooler air from outside the hood.
Any input would be appreciated. Thanks
Old 06-12-2008, 10:20 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to the site.
You might want to check this thread for info about CAI vs. Warm/Hot Air Intake:
Cold air VS Warm Air Intakes - what's the difference?
Old 06-14-2008, 03:42 PM   #3 (permalink)
inflation pressure
I do not have any current data.The data I do have suggests that while under-inflation robs fuel,over-inflating shows no significant improvement in economy,and can have a deleterious effect on brake bias,effecting oversteer/understeer characteristics of the vehicle.Inflation pressures are established by the carmaker for brake bias,favoring understeer,where the front tires break loose first,and a simple steering input restores direction.Personally,I'd stay with carmaker specs,regardless of max. pressure ratings.Saving a fraction of fuel is not worth your safety.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
My Continental Contact-Pro Tires cfg83 EcoModding Central 16 05-08-2010 01:33 PM
PSI question Frankenstipe Hypermiling / EcoDriver's Ed 9 06-06-2008 07:05 AM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
