EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Newbe, 2001 Civic HX (https://ecomodder.com/forum/showthread.php/newbe-2001-civic-hx-32164.html)
Howzit 06-14-2015 10:45 AM
Hello Everyone. Been lurking for years, thought I'd finally join. Picked up a 01 Civic HX a few months ago. It's the CA model, but I've been happy with the economy so far.
I added the fuel log info for the Civic. It was easy, just 8 fill ups since I bought it. I also have an Acura TSX. I've 150 fill ups logged for it. Is there an easy way to import them to this site, like you can on fuelly? I really don't want to do it one by one.
Thank You
Xist 06-14-2015 11:33 PM
Welcome! Sorry, I do not know anything about the fuel logs; hopefully someone else speaks up. Do you have any modifications planned? Do you have a meter?
Daox 06-15-2015 09:57 AM
Welcome to the site Howzit! The Civic is definitely a nice car to get good mileage with.
PM MetroMPG about the fuel log issue. I'm pretty sure he can import it for you.
Howzit 06-15-2015 11:23 AM
Thank you.
No real mods planned. I have the tires at max pressure and run a scangauge. I'm thinking about getting the ultraguage, so I can monitor lean burn.
darcane 06-15-2015 01:21 PM
Thank You
Welcome.
I've got the same car, CA model and everything, see the link in my sig.
Any problems other than the headgasket? Headgasket failures and tranny problems are very common on these Civics.
Howzit 06-15-2015 01:40 PM
Originally Posted by darcane (Post 483523)
Welcome.
Other than the head gasket, it's been fine. It threw a cel at me one day, tdc sensor. I pushed on the connection to make sure it was tight and cleared the code. It hasn't came back since. What are the tranny issues with this generation? I can tell it's a good car, but it doesn't seem as good as my last civic. She was a 6th gen EX coupe. Such a rock solid car. Put over 260k on her. Woke up one morning and she was gone. Broke my heart.
darcane 06-15-2015 04:12 PM
I hate that. I had my old motorcycle stolen. It was a little rough, but I loved that bike and put a bunch of miles on it.
Manual trannies tend to lose the Input Shaft Bearing (ISB), both of my trannies had that go out. Also, there is a bearing that can go if you run low on fluid that causes third gear to get noisy and start popping out of gear. Autos are also problematic. Honda had widespread issues with tranny failures from '01-'05 Civics and about '99-'04 Accords, Odysseys, and Pilots. There was a big class action lawsuit a while back on it.
I bought mine because of how fond I was of my old '95 EX coupe. Between the two, the '95 was definitely the better car.
