Old 12-04-2008, 12:40 PM   #1 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Optimising turbo boost control for fuel economy
Here's an interesting post from Julian at autospeed.
I would like to give it a shot in my TDI, but I'm not too sure how to go about it.
When messing with the MAP for more boost, some people add a diode to reduce the 0-5v MAP signal voltage, so the ECU thinks there is less boost and calls for more. Others replace the stock 2.5 bar MAP with a 3 bar to achieve similar results.
So I'm looking to do the opposite. I could replace my 2.5 bar MAP with a 2 bar MAP, but then I would have less boost even when I need it. I could add a second stock MAP just at the turbo's outlet and switch the input with a switch as suggested in the article, but that would cost me a 70 bucks MAP.
An other way, and potentially cheaper, would be the opposite of the diode on the signal wire mod. How would I go about building something simple and cheap that at the flip of a switch adds a fixed amount of voltage to the signal? Say I want to add 0.2V to the 0-5V signal?
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 12-04-2008, 04:36 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
The the max boost electronically or mechanically controlled by your car? Might not be tooo hard.
Old 12-04-2008, 10:09 PM   #3 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I've always wondered about messing with my engines stuff and see if i can do something similar. But I always think of the consequences of screwing up bad..
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Aftermarket Cruise Control setting for economy mavinwy EcoModding Central 2 08-25-2008 03:20 PM
Low-Drag Trucks: Aerodynamic Improvements & Flow Control System Boost Fuel Efficiency OokiiMamoru Aerodynamics 5 06-15-2008 11:38 PM
Using the climate control fan to increase economy OfficeLinebacker EcoModding Central 5 04-20-2008 01:58 AM
