Ninja 250 EV conversion: solar recharged & "Vetter style" streamlining
Via ABG this is a pretty interesting project: AltCar 2008: Prometheus' solar-powered electric motorcycle - AutoblogGreen
http://www.blogsmithmedia.com/www.au...motorcycle.jpg Jim Corning is owner of an Arizona PV solar installation business, and apparently as a hobby decided to appropriate his wife's Ninja 250 and transform it into the lithium powered machine you see above. The bike project was practice for a yet-to-be built car conversion. He uses it as a promotional tool for the business, and points out that he can power the bike for about 50 miles a day from the panels you see behind it. Top speed is 70 mph with a range of 40-50 miles in a mix of hwy/city. He built the fairing because he ruined a set of batteries by drawing too much current from them at highway speeds in the bike's original form and realized he needed to make it more efficient. He knows all about Craig Vetter, obviously! With the fairing, the top speed went up by 10 mph, and the current went down at lower speeds compared to the original bodywork. There's an audio interview with the builder and a photo gallery on ABG.. |
I'd love to do something like this with my scooter...
I sure hope that his work and Craig Vetters work seeps into the styling that is common in the industry. There is plenty of work to do and significant benefit for aerodynamically slippery motorcycles.
This guy has a really great technical start and it looks like an eye for good design as well. A rare and valuable combination. One thing I don't understand though is how the front wheel will steer while the suspension is compressed. |
I wrote to the builder , asking about the front suspension/fairing clearance question.
He writes: Quote:
I'd also be curious about how the rear fairing affects the centre of gravity i.e. how the added weight up high affects the handling.
I'd be curious how he fabricated that fairing--if it was a sculpted male plug followed by female mold of fiberglass, or what.
He's off to a good start. Fine tuning would include mirrors within the envelope of the windscreen, flush turn signals, coverage for the rider's legs, etc.. Center of gravity would not be a problem if he does not load up the trunk with heavy stuff. |
very cool of the guy to write back I would think the front shocks would be inside of the housing as there is visually no room for up/down travel |
I wonder how those aeromods handle in cross winds. traditional motorcycles can be tricky to begin with when there are cross wind conditions. Even a bicycle with wheel disks is often difficult to steer.
NOW, look at the centre of pressure and how far aft it is! fUN FuN fuN to prove that concept just pilot a tandem with an unsteady rider in the back! |
Hey this guy is in my home town. i cant believe i haven't seen this thing around
Looks like he has since updated the faring. http://prometheussolar.com/images/ph...torcycle_2.jpg http://prometheussolar.com/Motorcycle.aspx |
who knew spies were so aero ;) http://www.gomonews.com/wp-content/u...mbs-775529.jpg |
Now, this is the streamliner I'd gladly try. We only need a better battery pack at the same weight at most, to get a really usable range (like 300 or more miles) :thumbup: |
I have had some experiences with bicycles and fairings. I now mount the nose piece to the frame rather than the handle bars so that the side pressure does not affect the steering. My latest bike uses a 20" mag wheel in the front with a shallow angled frame. A faired front wheel needs fin area behind the steering axis for stability much the same as the whole bike needs the center of pressure behind the center of mass to head into the wind.
How would a person get started making a fairing that beautiful? I've never done any auto-body work or metal fabrication so I'd be starting from scratch.
Start at the local library and look for books on composite materials and fiberglass construction. There are books on building racecars, boats, and aircraft that have good techniques. Making a fiberglass mold is a lot of work unless you plan to make more than one. If you are good at calculus or sheet metal development drawing, you can do things with honeycomb or sheets of material bonded to foam insulation. My book on composite materials is by Keith Noakes.
The WISIL website has anecdotes of racers who have crashed their streamlined recumbents. The consensus is that the skins protected them from abrasion
(road rash). A good fairing design and a lap belt can go a long way to protecting a rider on two wheels from injury in a traffic accident while enjoying that sense of freedom we love so much. |
